Adaptive wavelet thresholding for image denoising and compression, IEEE Transactions on Image Processing, vol.9, issue.9, pp.1532-1546, 2000. ,
The curvelet transform for image denoising, IEEE Transactions on Image Processing, vol.11, issue.6, pp.670-684, 2002. ,
Color image denoising via sparse 3D collaborative filtering with grouping constraint in luminance-chrominance space, IEEE International Conference on Image Processing (ICIP), pp.313-316, 2007. ,
, Bilateralfilteringforgrayandcolorimages. IEEE International Conference on Computer Vision (ICCV), pp.839-846, 1998.
A non-local algorithm for image denoising, IEEE Conference on Computer Vision and Pattern Recognition (CVPR), pp.60-65, 2005. ,
Weighted nuclear norm minimization with application to image denoising, IEEE Conference on Computer Vision and Pattern Recognition (CVPR), pp.2862-2869, 2014. ,
From learning models of natural image patches to whole image restoration, IEEE International Conference on Computer Vision (ICCV), pp.479-486, 2011. ,
On learning optimized reaction diffusion processes for effective image restoration, IEEE Conference on Computer Vision and Pattern Recognition (CVPR), pp.5261-5269, 2015. ,
Region-based non-local means algorithm for noise removal, lectronics Letters, 2011. ,
Non-local means algorithm with adaptive patch size and bandwidth, Optik, vol.124, pp.5639-5645, 2013. ,
A novel Non-local means image denoising method based on grey theory, Pattern Recognition ,
Non Local Means Algorithm with Adaptive Isotropic Search Window Size for Image Denoising, IEEE INDICON ,
Noise Suppression by Discontinuity Indicator Controlled Non-local Means Method, 2017. ,
An Improved Non-Local Means Algorithm for Image Denoising, IEEE 2nd International Conference on Signal and Image Processing, 2017. ,
Pruned non-local means, IET Image Processing, 2017. ,
An improved non-local means image denoising algorithm, IEEE International Conference on Information and Automation (ICIA), 2017. ,
A Holistic Approach to Cross-Channel Image Noise Modeling and its Application to Image Denoising, IEEE Conference on Computer Vision and Pattern Recognition (CVPR), 2016. ,
External Prior Guided Internal Prior Learning for Real Noisy Image Denoising, Computer Vision and Pattern Recgnition, 2017. ,
Multi-channel Weighted Nuclear Norm Minimization for Real Color Image Denoising, Computer Vision and Pattern Recgnition, 2017. ,
DOA estimation in the presence of unknown non-uniform noise with coprime array, lectronics Letters, 2017. ,
Noise Reduction for Images with Non-uniform Noise Using Adaptive Block Matching 3D Filtering, Chinese Journal of Electronics, 2017. ,
Benchmarking Denoising Algorithms with Real Photographs, IEEE Conference on Computer Vision and Pattern Recognition (CVPR), 2017. ,
An efficient statistical method for image noise level estimation, IEEE International Conference on Computer Vision (ICCV), 2015. ,
