Clustering by Passing Messages Between Data Points, Science, vol.315, issue.5814, pp.972-976, 2007. ,
A novel intelligent method for bearing fault diagnosis based on affinity propagation clustering and adaptive feature selection. Knowledge-Based Systems, vol.116, pp.1-12, 2017. ,
A Nyström spectral clustering algorithm based on probability incremental sampling. Soft Computing, vol.21, pp.5815-5827, 2017. ,
Dual-Strategy Differential Evolution with Affinity Propagation Clustering for Multimodal Optimization Problems, IEEE Transactions on Evolutionary Computation, 2017. ,
Dynamic equivalent modeling of two-staged photovoltaic power station clusters based on dynamic affinity propagation clustering algorithm, International Journal of Electrical Power & Energy Systems, vol.95, pp.463-475, 2018. ,
Adjustable preference affinity propagation clustering, Pattern Recognition Letters, vol.85, pp.72-78, 2017. ,
Adaptive density distribution inspired affinity propagation clustering, Neural Computing and Applications, vol.2017, pp.1-11 ,
Generating Specified K Clusters by Efficient Affinity Propagation, Proceedings 2010 10th IEEE International Conference on Data Mining (ICDM 2010), pp.1187-1192, 2010. ,
Self-tuning p-spectral clustering based on shared nearest neighbors, Cognitive Computation, vol.7, issue.5, pp.622-632, 2015. ,
Density peaks clustering based integrate framework for multidocument summarization, CAAI Transactions on Intelligence Technology, vol.2, issue.1, pp.26-30, 2017. ,
Semi-supervised affinity propagation with soft instance-level constraints, IEEE transactions on pattern analysis and machine intelligence, vol.37, pp.1041-1052, 2015. ,
Manifold alignment using discrete surface Ricci flow, CAAI Transactions on Intelligence Technology, vol.1, issue.3, pp.285-292, 2016. ,
The latest research progress on spectral clustering, Neural Computing & Applications, vol.24, issue.7-8, pp.1477-1486, 2014. ,
Approximate normalized cuts without Eigen-decomposition, Information Sciences, vol.374, pp.135-150, 2016. ,
A density-adaptive affinity propagation clustering algorithm based on spectral dimension reduction, Neural Computing & Applications, vol.25, issue.7-8, pp.1557-1567, 2014. ,
Adaptive message update for fast affinity propagation, Proceedings of the 21th ACM SIGKDD international conference on knowledge discovery and data mining, pp.309-318, 2015. ,
