Abstract : In the open social networks, the analysis of user data after the injection attack has a great impact on the recommendation system. K-Nearest Neighbor-based collaborative filtering algorithms are very vulnerable to this attack. Another recommendation algorithm based on probabilistic latent semantic analysis has relatively accurate recommendation, but it is not very stable and robust against attacks on the overall user data of the recommendation system. Here is used to DeepWalk the user network processing, while taking advantage of the user profile feature time series to consider the user’s behavior over time, the algorithm also analyzes the stability and robustness of DeepWalk and user profile. The results show that especially the DeepWalk-based approach can achieve comparable recommendation accuracy.
https://hal.inria.fr/hal-02197806 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Tuesday, July 30, 2019 - 5:02:35 PM Last modification on : Tuesday, July 30, 2019 - 5:12:14 PM
Xu Gao, Wenjia Niu, Jingjing Liu, Tong Chen, yingxiao Xiang, et al.. A DeepWalk-Based Approach to Defend Profile Injection Attack in Recommendation System. 10th International Conference on Intelligent Information Processing (IIP), Oct 2018, Nanning, China. pp.213-222, ⟨10.1007/978-3-030-00828-4_22⟩. ⟨hal-02197806⟩
