Ekstrakto A tool to reconstruct Dedukti proofs from TSTP files (extended abstract) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Proof assistants often call automated theorem provers to prove subgoals. However, each prover has its own proof calculus and the proof traces that it produces often lack many details to build a complete proof. Hence these traces are hard to check and reuse in proof assistants. DEDUKTI is a proof checker whose proofs can be translated to various proof assistants: Coq, HOL, Lean, Matita, PVS. We implemented a tool that extracts TPTP subproblems from a TSTP file and reconstructs complete proofs in DEDUKTI using automated provers able to generate DEDUKTI proofs like ZenonModulo or ArchSAT. This tool is generic: it assumes nothing about the proof calculus of the prover producing the trace, and it can use different provers to produce the DEDUKTI proof. We applied our tool on traces produced by automated theorem provers on the CNF problems of the TPTP library and we were able to reconstruct a proof for a large proportion of them, significantly increasing the number of DEDUKTI proofs that could be obtained for those problems.
Mots clés
main.pdf (109.41 Ko) Télécharger le fichier
hal-02200548 , version 1 (31-07-2019)
Mohamed Yacine El Haddad, Guillaume Burel, Frédéric Blanqui. Ekstrakto A tool to reconstruct Dedukti proofs from TSTP files (extended abstract). PxTP 2019 - Sixth Workshop on Proof eXchange for Theorem Proving (PxTP), Aug 2019, Natal, Brazil. pp.27-35, ⟨10.4204/EPTCS.301.5⟩. ⟨hal-02200548⟩
153 Consultations
221 Téléchargements
