Preprints, Working Papers, ...
On the derivation of guaranteed and p-robust a posteriori error estimates for the Helmholtz equation
Abstract : We propose a novel a posteriori error estimator for conforming finite element discretizations of two-and three-dimensional Helmholtz problems. The estimator is based on an equilibrated flux that is computed through the solve of patchwise mixed finite element problems. We show that the estimator is reliable up to a prefactor that tends to one with mesh refinement or with polynomial degree increase. We also derive a fully computable upper bound on this prefactor for several common settings of domains and boundary conditions, leading to a guaranteed estimate in all wavenumber regimes without any assumption on the mesh size or the polynomial degree. We finally demonstrate that the estimator is locally efficient as soon as the mesh exhibits sufficiently many degrees of freedom per wavelength. In such a regime, the estimator is also robust with respect to the polynomial degree. We present numerical experiments that illustrate our analysis and indicate that our theoretical results are sharp.
Complete list of metadatas
Cited literature [51 references]  Display  Hide  Download
https://hal.inria.fr/hal-02202233
Contributor : Théophile Chaumont-Frelet <>
Submitted on : Wednesday, July 31, 2019 - 4:13:44 PM
Last modification on : Thursday, March 5, 2020 - 3:27:14 PM
Identifiers
  • HAL Id : hal-02202233, version 1
Citation
Théophile Chaumont-Frelet, Alexandre Ern, Martin Vohralík. On the derivation of guaranteed and p-robust a posteriori error estimates for the Helmholtz equation. 2019. ⟨hal-02202233⟩
Share
Metrics
Record views
175
Files downloads
470
