Sobolev spaces, 2003. ,
Discrete dispersion relation for hp-version finite element approximation at high wave number, SIAM J. Numer. Anal, vol.42, issue.2, pp.553-575, 2004. ,
Sur l'évaluation de l'erreur d'interpolation de lagrange dans un ouvert de R n, R.A.I.R.O. Analyse numérique, vol.10, issue.3, pp.5-27, 1976. ,
A posteriori error estimation for finite element solutions of Helmholtz equation. Part I: the quality of local indicators and estimators, Int. J. Numer. Meth. Engrg, vol.40, pp.3883-3900, 1997. ,
Efficient implementation of high-order finite elements for Helmholtz problems, Int. J. Numer. Meth. Engng, vol.106, pp.213-240, 2016. ,
Equilibrated residual error estimates are p-robust, Comput. Meth. Appl. Mech. Engrg, vol.198, pp.1189-1197, 2009. ,
Guaranteed and robust a posteriori bounds for Laplace eigenvalues and eigenvectors: conforming approximations, SIAM J. Numer. Anal, vol.55, issue.5, pp.2228-2254, 2017. ,
Guaranteed lower bounds for eigenvalues, Math. Comp, vol.83, issue.290, pp.2605-2629, 2014. ,
Explicit error estimates for Courant, Crouzeix-Raviart and Raviart-Thomas finite element methods, J. Comp. Math, vol.30, issue.4, pp.337-353, 2012. ,
Asymptotic exactness of the least-squares finite element residual, SIAM J. Numer. Anal, vol.56, issue.4, 2008. ,
, High-frequency bounds for the Helmholtz equation under parabolic trapping and applications in numerical analysis, 2017.
Wavenumber explicit convergence analysis for finite element discretizations of general wave propagation problems, ESAIM Math. Model. Numer. Anal, vol.5, 2018. ,
Uniform a priori estimates for elliptic problems with impedance boundary conditions, submitted, p.1887269, 2018. ,
Inverse problems in wave propagation, 2012. ,
Guaranteed and robust a posteriori error estimates for singularly perturbed reaction-diffusion problems, ESAIM Math. Model. Numer. Anal, vol.43, pp.867-888, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-00271527
The finite element method for elliptic problems, 2002. ,
Inverse acoustic and electromagnetic scattering theory, 2012. ,
Robust adaptive hp discontinuous Galerkin finite element methods for the Helmholtz equation, SIAM J. Sci. Comput, vol.41, issue.2, pp.1121-1147, 2019. ,
A remark on the regularity of solutions to Maxwell's equations in Lipschitz domains, Math. Meth. Appl. Sci, vol.12, pp.365-368, 1990. ,
Goal-oriented adaptivity using unconventional error representations for the 1D Helmholtz equation, Comput. Math. Appl, vol.69, pp.964-979, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01140748
Computational electromagnetics for RF and microwave engineering, 2010. ,
, Computing with hp-adaptive finite elements, vol.1, 2006.
Explicit error bounds in a conforming finite element method, Math. Comp, vol.68, issue.228, pp.1379-1396, 1999. ,
MMG3D: User guide, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00681813
hp-adaptation driven by polynomial-degree-robust a posteriori error estimates for elliptic problems, SIAM J. Sci. Comput, vol.38, issue.5, pp.3220-3246, 2016. ,
A posteriori error estimation for highly indefinite Helmholtz problems, Comput. Meth. Appl. Math, vol.13, pp.333-347, 2013. ,
Polynomial-degree-robust a posteriori estimates in a unified setting for conforming, nonconforming, discontinuous Galerkin, and mixed discretizations, SIAM J. Numer. Anal, vol.53, issue.2, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-00921583
Finite element methods for Navier-Stokes equations: theory and algorithms, 1986. ,
Singularities in boundary value problems, 1992. ,
Stability estimates for a class of Helmholtz problems, Commun. Math. Sci, vol.5, issue.3, pp.665-678, 2007. ,
Discrete regular decomposition of tetrahedral discrete 1-forms, 2017. ,
A residual a posteriori error estimator for the finite element solution of the Helmholtz equation, Comput. Meth. Appl. Mech. Engrg, vol.190, pp.4027-4042, 2001. ,
A Babu?ka-Aziz proof of the circumradius condition, Japan J. Indust. Appl. Math, vol.31, pp.193-210, 2014. ,
Comparaison de modèles de milieux continus, 1975. ,
A framework of verified eigenvalue bounds for self-adjoint differential operators, Appl. Math. Comput, vol.267, pp.341-355, 2015. ,
Analysis and estimation of error constants for P 0 and P 1 interpolations over triangular finite elements, J. Math. Sci. Univ. Tokyo, vol.17, issue.1, pp.27-78, 2010. ,
Developments in structural-acoustic optimization for passive noise control, Arch. Comput. Meth. Engng, vol.9, issue.4, pp.291-370, 2002. ,
42. , hp-interpolation of nonsmooth functions and an aplication to hp-a posteriori error estimation, SIAM J. Numer. Anal, vol.43, issue.1, pp.127-155, 1995. ,
Wavenumber explicit convergence analysis for Galerkin discretizations of the Helmholtz equation, SIAM J. Numer. Anal, vol.49, issue.3, pp.1210-1243, 2011. ,
Mixed finite elements in R 3, Numer. Math, vol.35, pp.315-341, 1980. ,
Asymptotic a posteriori finite element bounds for the outputs of noncoercive problems: the Helmholtz and Burgers equations, Comput. Meth. Appl. Mech. Engrg, vol.171, pp.77-86, 1999. ,
Approximations in elasticity based on the concept of function space, Quart. Appl. Math, vol.5, issue.3, pp.241-269, 1947. ,
A mixed finite element method for 2nd order elliptic problems, Mathematical Aspect of Finite Element Methods, 1977. ,
A posteriori finite element error bounds for non-linear outputs of the Helmholtz equation, Int. J. Numer. Meth. Fluids, vol.31, pp.17-36, 1999. ,
A posteriori error estimation of hp-dG finite element methods for highly indefinite Helmholtz problems, SIAM J. Numer. Anal, vol.53, issue.5, pp.2414-2440, 2015. ,
Wavenumber-explicit bounds in time-harmonic acoustic scattering, SIAM J. Math. Anal, vol.46, issue.4, pp.2987-3024, 2014. ,
Explicit residual-based a posteriori error estimation for finite element discretizations of the Helmholtz equation: computation of the constant and new measures of error estimator quality, Comput. Meth. Appl. Mech. Engrg, vol.131, pp.1-26, 1996. ,
Pollution-free and fast hybridizable discontinuous Galerkin solvers for the high-frequency Helmholtz equation, Proc. SEG annual meeting, 2017. ,
Poincaré constants for finite element stars, IMA J. Numer. Anal, vol.32, issue.1, pp.30-47, 2012. ,
A posteriori error estimation techniques for finite element methods, Numerical Mathematics and Scientific Computation, 2013. ,
A simple error estimator and adaptive procedure for practical engineering analysis, Internat. J. Numer. Methods Engrg, vol.24, issue.2, pp.337-357, 1987. ,
