Integrated Circuit and Systems, Algorithms and Architectures, vol.39, p.40, 2014. ,
, Deep learning, vol.1, 2016.
Lossy image compression with compressive autoencoders, Int. Conf. on Learning Representations (ICLR), 2017. ,
Soft-to-hard vector quantization for endto-end learning compressible representations, Advances in Neural Information Processing Systems, pp.1141-1151, 2017. ,
Spatially adaptive image compression using a tiled deep network, 2017 IEEE International Conference on Image Processing (ICIP), pp.2796-2800, 2017. ,
Real-time adaptive image compression, 2017. ,
Variational image compression with a scale hyperprior, Int. Conf. on Learning Representations (ICLR), 2018. ,
Generative adversarial networks for extreme learned image compression, 2018. ,
CNNbased prediction for lossless coding of photographic images, 2018 Picture Coding Symposium (PCS), pp.16-20, 2018. ,
Quality assessment of deeplearning-based image compression, Multimedia Signal Processing, 2018. ,
End-to-end optimized image compression, Int. Conf. on Learning Representations (ICLR), 2017. ,
Full resolution image compression with recurrent neural networks, IEEE Int. Conf. on Computer Vision and Pattern Recognition (CVPR), pp.5435-5443, 2017. ,
Context encoders: feature learning by inpainting, Proceedings of the IEEE conference on computer vision and pattern recognition, pp.2536-2544, 2016. ,
Variational learning and bits-back coding: an information-theoretic view to bayesian learning, IEEE Transactions on Neural Networks, vol.15, issue.4, pp.800-810, 2004. ,
Auto-encoding variational bayes, Int. Conf. on Learning Representations (ICLR), 2014. ,
ADAM: A method for stochastic optimization, 2014. ,
Understanding the difficulty of training deep feedforward neural networks, Proceedings of the thirteenth international conference on artificial intelligence and statistics, pp.249-256, 2010. ,
Will people like your image?, 2016. ,
Digital coding of waveforms: principles and applications to speech and video, pp.115-251, 1984. ,
