Multi-dimensional hyperbolic partial differential equations. first order systems and applications, 2007. ,
Why many theories of shock waves are necessary: kinetic relations for non-conservative systems, Proceedings of the Royal Society of Edinburgh: Section A Mathematics, vol.142, pp.1-37, 2012. ,
Vanishing viscosity solutions of nonlinear hyperbolic systems, Ann. of Math, issue.2, p.35160, 2005. ,
On the mathematical modelling of a compressible viscoelastic fluid, MR 2927616, vol.205, pp.1-26, 2012. ,
A two-phase shallow debris flow model with energy balance, Math. Model. Numer. Anal, vol.49, issue.1, pp.101-140, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-00860871
Entropy satisfying flux vector splittings and kinetic BGK models, Numerische Mathematik, vol.94, pp.623-672, 2003. ,
, Nonlinear stability of finite volume methods for hyperbolic conservation laws and well-balanced schemes for sources, Frontiers in Mathematics, p.65002, 2004.
, A reduced stability condition for nonlinear relaxation to conservation laws, J. Hyperbolic Differ. Equ, vol.1, issue.1, p.35258, 2004.
A new model for shallow viscoelastic fluids, M3AS, vol.23, issue.08, pp.1479-1526, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00628651
, Unified derivation of thin-layer reduced models for shallow freesurface gravity flows of viscous fluids, Eur. J. Mech. B Fluids, vol.55, pp.116-131, 2016.
Derivation and numerical approximation of hyperbolic viscoelastic flow systems: Saint-Venant 2D equations for Maxwell fluids, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01661269
, Segalman-Saint-Venant equations for a 1d viscoelastic shallow flow in pure elastic limit, Theory, Numerics and Applications of Hyperbolic Problems I (Cham, pp.205-213, 2018.
Error estimate for time-explicit finite volume approximation of strong solutions to systems of conservation laws, SIAM Journal on Numerical Analysis, vol.54, issue.2, pp.1263-1287, 2016. ,
Hyperbolic conservation laws with stiff relaxation terms and entropy, Comm. Pure Appl. Math, vol.47, issue.6, 1994. ,
Global illposedness of the isentropic system of gas dynamics, Communications on Pure and Applied Mathematics, vol.68, issue.7, pp.1157-1190, 2015. ,
A symmetrizable extension of polyconvex thermoelasticity and applications to zero-viscosity limits and weak-strong uniqueness, Communications in Partial Differential Equations, vol.0, issue.0, pp.1-32, 2018. ,
, Hyperbolic conservation laws in continuum physics, vol.325, 2000.
Théorie du mouvement non-permanent des eaux, avec application aux crues des rivières età l'introduction des marées dans leur lit, C. R. Acad. Sc. Paris, vol.73, pp.147-154, 1871. ,
A variational approximation scheme for three-dimensional elastodynamics with polyconvex energy, Archive for Rational Mechanics and Analysis, vol.157, issue.4, pp.325-344, 2001. ,
Weakstrong uniqueness of dissipative measure-valued solutions for polyconvex elastodynamics, Archive for Rational Mechanics and Analysis, vol.205, issue.3, pp.927-961, 2012. ,
Numerical methods for eulerian and lagrangian conservation laws, Frontiers in Mathematics (FM), 2017. ,
Lagrangian gas dynamics in two dimensions and lagrangian systems, MR 2196496, vol.178, pp.327-372, 2005. ,
, The theory of polymer dynamics, 1998.
Remarks concerning compressible viscoelastic fluid models, Journal of Non-Newtonian Fluid Mechanics, vol.36, pp.411-417, 1990. ,
Multidimensional shear shallow water flows : problems and solutions, 2017. ,
Derivation of viscous SaintVenant system for laminar shallow water ; numerical validation, Discrete and continuous dynamical system Series B, vol.1, issue.1, pp.89-102, 2001. ,
URL : https://hal.archives-ouvertes.fr/inria-00072549
Numerical approximation of hyperbolic systems of conservation laws, Applied Mathematical Sciences, vol.118, 1996. ,
Finite difference method for numerical computation of discontinous solution of the equations of fluid dynamics, Mat. Sb. (N.S.), vol.47, pp.271-300, 1959. ,
A new hyperbolic model and an experimental study for the flow of polymer melts in multi-pass rheometer, Computers & Fluids, vol.44, issue.1, pp.258-266, 2011. ,
A unified hyperbolic model for viscoelastic liquids, Mechanics Research Communications, vol.37, issue.2, pp.158-163, 2010. ,
Hydrodynamics of free surface flows. modelling with the finite element method, 2007. ,
The unified coordinate system in computational fluid dynamics, Commun. Comput. Phys, vol.2, issue.4, 2007. ,
Nonlinear resonance in systems of conservation laws, SIAM Journal on Applied Mathematics, vol.52, issue.5, pp.1260-1278, 1992. ,
Error estimates for finite volume approximations of classical solutions for nonlinear systems of hyperbolic balance laws, SIAM Journal on Numerical Analysis, vol.43, issue.6, pp.2423-2449, 2006. ,
The cauchy problem for quasi-linear symmetric hyperbolic systems, Archive for Rational Mechanics and, Analysis, vol.58, issue.3, pp.181-205, 1975. ,
Simulation of viscoelastic fluid flow, Fundamentals of Computer Modeling for Polymer Processing, pp.402-470, 1989. ,
Discretization of hyperelasticity on unstructured mesh with a cell-centered lagrangian scheme, J. Comput. Phys, vol.229, issue.24, pp.9092-9118, 2010. ,
Entropy weak solutions to nonlinear hyperbolic systems in nonconservation form, pp.362-373, 1989. ,
Elastic-plastic deformation at finite strains, ASME. J. Appl. Mech, vol.36, issue.1, pp.1-6, 1969. ,
Finite volume methods for hyperbolic problems, Cambridge Texts in Applied Mathematics, p.65001, 2002. ,
, Mathematical topics in fluid mechanics, vol.1, 1996.
Compressible fluid flow and systems of conservation laws in several space variables, Applied Mathematical Sciences, vol.53, 1984. ,
Derivation of a new two-dimensional viscous shallow water model with varying topography, bottom friction and capillary effects, European Journal of Mechanics-B/Fluids, vol.26, issue.1, pp.49-63, 2007. ,
URL : https://hal.archives-ouvertes.fr/hal-02067998
Lectures on geometric models in mathematical physics, CBMS-NSF Regional Conference Series in Applied Mathematics, SIAM, 1981. ,
Xiii. the bakerian lecture.-on the viscosity or internal friction of air and other gases, Philosophical Transactions of the Royal Society of London, vol.156, pp.249-268, 1866. ,
on the dynamical theory of gases, Philosophical Transactions of the Royal Society of London, vol.157, pp.49-88, 1867. ,
on double refraction in a viscous fluid in motion, Proceedings of the Royal Society of London, vol.22, issue.148, pp.46-47, 1874. ,
L 2 well-posed Cauchy problems and symmetrizability of first order systems, J.Éc. polytech. Math, vol.1, 2014. ,
Rational extended thermodynamics, Springer Tracts in Natural Philosophy, vol.37, 1998. ,
On a shallow water model for nonnewtonian fluids, Numerical Mathematics and Advanced Applications, pp.693-701, 2009. ,
The elastic metric: A review of elasticity with large distortions, International Journal of Non-Linear Mechanics, vol.56, pp.34-42, 2013. ,
Blow-up of solutions of first order quasilinear hyperbolic equations, Appl. Anal, vol.51, issue.1-4, 1993. ,
Some properties of the upper convected maxwell model for viscoelastic fluid flow, Journal of Non-Newtonian Fluid Mechanics, vol.48, issue.1-2, pp.125-145, 1993. ,
, Stochastic processes in polymeric fluids, p.76008, 1996.
, Computational rheology, 2002.
Theoretical and numerical comparison of hyperelastic and hypoelastic formulations for Eulerian non-linear elastoplasticity, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-02044099
A hyperbolic model for viscous newtonian flows, Continuum Mechanics and Thermodynamics, vol.28, issue.1, pp.85-104, 2016. ,
A purely hyperbolic model for unsteady viscoelastic flow, Journal of Non-Newtonian Fluid Mechanics, vol.32, issue.2, pp.197-224, 1989. ,
Mémoire sur leséquations générales de l'équilibre et du mouvement des corps solidesélastiques et des fluides, J. Ec. Polytech. cahier, vol.20, pp.1-174, 1831. ,
Symmetrizing nonlinear elastodynamic system, J. Elasticity, vol.50, issue.3, pp.245-252, 1998. ,
Mathematical analysis of viscoelastic flows, CBMS-NSF Conference Series in Applied Mathematics, vol.73, 2000. ,
On Maxwell models in viscoelasticity that are more computable, International Journal of Non Linear Mechanics, vol.35, pp.567-571, 2000. ,
Gas-dynamic analogy for vortex free-boundary flows, Journal of Applied Mechanics and Technical Physics, vol.48, issue.3, pp.303-309, 2007. ,
Existence of global weak solutions for 3d degenerate compressible navier-stokes equations, Inventiones mathematicae, vol.206, issue.3, pp.935-974, 2016. ,
Symmetric-hyperbolic equations of motion for a hyperelastic material, J. Hyperbolic Differ. Equ, vol.6, issue.3, 2009. ,
Conservation laws, coordinate transformations, and differential forms, Hyperbolic Problems: Theory, Numerics, Applications, pp.471-477, 1994. ,
Thermodynamics of viscoelastic fluids: the temperature equation, J. Rheol, vol.42, issue.5, pp.999-1019, 1998. ,
