Global-in-Time Domain Decomposition for a Nonlinear Diffusion Problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We study a simplified model for two–phase flow in porous media, where the medium is made of two (or more) different rock types. Each rock type is a subdomain with a distinct capillary pressure function so that the saturation becomes discontinuous across the interface between the different regions. This leads to the phenomenon of capillary trapping (see [12] or [4]).
Kern_DD25_proc.pdf (510.25 Ko) Télécharger le fichier
hal-02263280 , version 1 (03-08-2019)
Elyes Ahmed, Caroline Japhet, Michel Kern. Global-in-Time Domain Decomposition for a Nonlinear Diffusion Problem. DD 2018 - 25th International Domain Decomposition Conference, Jul 2018, St John's, Canada. pp.202-209, ⟨10.1007/978-3-030-56750-7⟩. ⟨hal-02263280⟩
88 Consultations
250 Téléchargements
