, Robotics: Modeling, Planning and Control, 2008.
Robot collisions: A survey on detection, isolation, and identification, IEEE Transactions on Robotics, vol.33, issue.6, pp.1292-1312, 2017. ,
Hybrid force/velocity control for physical human-robot collaboration tasks, Proc. IEEE/RSJ Int. Conf. on Intelligent Robots and Systems, 2016. ,
Model identification, pp.321-344, 2008. ,
A generic instrumental variable approach for industrial robot identification, IEEE Transactions on Control Systems Technology, vol.22, issue.1, pp.132-145, 2014. ,
Humanoid and human inertia parameter identification using hierarchical optimization, IEEE Transactions on Robotics, vol.32, issue.3, pp.726-735, 2016. ,
URL : https://hal.archives-ouvertes.fr/lirmm-01348410
Optimal exciting dance for identifying inertial parameters of an anthropomorphic structure, IEEE Transactions on Robotics, vol.32, issue.4, pp.823-836, 2016. ,
URL : https://hal.archives-ouvertes.fr/lirmm-01346044
Extracting feasible robot parameters from dynamic coefficients using nonlinear optimization methods, Proc. IEEE Int. Conf. on Robotics and Automation, pp.2075-2081, 2016. ,
Modeling, Identification and Control of Robots, Hermes, 2002. ,
V-REP virtual robot experimentation platform, 2015. ,
Dynamic parameter identification in industrial robots considering physical feasibility, Advanced Robotics, vol.19, issue.1, pp.101-119, 2005. ,
Physical feasibility of robot base inertial parameter identification: A linear matrix inequality approach, Int. J. of Robotics Research, vol.33, issue.6, pp.931-944, 2014. ,
Linear matrix inequalities for physically-consistent inertial parameter identification: A statistical perspective on the mass distribution, IEEE Robotics and Automation Letters, pp.1-1, 2017. ,
Inertia tensor properties in robot dynamics identification: A linear matrix inequality approach, IEEE/ASME Transactions on Mechatronics, pp.1-1, 2019. ,
Identification of fully physical consistent inertial parameters using optimization on manifolds, 2016 IEEE/RSJ International Conference on Intelligent Robots and Systems (IROS), pp.5446-5451, 2016. ,
Modeling and control of elastic joint robots, ASME J. Dyn. Syst. Meas. Control, vol.109, issue.4, pp.310-319, 1987. ,
Identifying the dynamic model used by the KUKA LWR: A reverse engineering approach, 2014 IEEE International Conference on Robotics and Automation (ICRA), pp.1386-1392, 2014. ,
Dynamic model identification for industrial robots, IEEE Control Systems Mag, vol.27, issue.5, pp.58-71, 2007. ,
Dynamic identification of the Kuka LightWeight robot: Comparison between actual and confidential Kuka's parameters, 2014 IEEE/ASME International Conference on Advanced Intelligent Mechatronics, pp.483-488, 2014. ,
, Machine Learning, 1997.
, Artificial Intelligence: A Modern Approach, 2009.
Constrained Optimization and Lagrange Multiplier Methods, Athena Scientific, 1996. ,
