Dynamic identification of the Franka Emika Panda robot with retrieval of feasible parameters using penalty-based optimization, IEEE Robotics and Automation Lett, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-02265294
Direct calculation of minimum set of inertial parameters of serial robots, IEEE Trans. on Robotics and Automation, vol.6, issue.3, pp.368-373, 1990. ,
Physical feasibility of robot base inertial parameter identification: A linear matrix inequality approach, Int. J. of Robotics Research, vol.33, issue.6, pp.931-944, 2014. ,
, Inertia tensor properties in robot dynamics identification: A linear matrix inequality approach, IEEE/ASME Transactions on Mechatronics, pp.1-1, 2019.
V-REP virtual robot experimentation platform, 2015. ,
