Histopathologic analysis of foci of signal loss on gradient-echo t2*-weighted mr images in patients with spontaneous intracerebral hemorrhage: evidence of microangiopathy-related microbleeds, American Journal of Neuroradiology, vol.20, issue.4, pp.637-642, 1999. ,
Nuclear induction, Phys. Rev, vol.70, pp.460-474, 1946. ,
Halving mr imaging time by conjugation: demonstration at 3.5 kg, Radiology, vol.161, issue.2, pp.527-531, 1986. ,
SENSE: sensitivity encoding for fast MRI, Magnetic Resonance in Medicine, vol.42, issue.5, pp.952-962, 1999. ,
Generalized autocalibrating partially parallel acquisitions (grappa), Magnetic Resonance in Medicine: An Official Journal of the International Society for Magnetic Resonance in Medicine, vol.47, issue.6, pp.1202-1210, 2002. ,
, Controlled aliasing in volumetric parallel imaging, vol.55, pp.549-556, 2006.
Compressed sensing, IEEE Transactions on Information Theory, vol.52, issue.4, pp.1289-1306, 2006. ,
URL : https://hal.archives-ouvertes.fr/inria-00369486
Sparse MRI: The application of compressed sensing for rapid MR imaging, Magnetic Resonance in Medicine, vol.58, issue.6, pp.1182-1195, 2007. ,
Fast 3D imaging using variable-density spiral trajectories with applications to limb perfusion, Magnetic Resonance in Medicine, vol.50, issue.6, pp.1276-1285, 2003. ,
Sparkling: variable-density k-space filling curves for accelerated t2*-weighted mri, 2019. ,
Nonuniform fast Fourier transforms using min-max interpolation, 2003. ,
Using NFFT 3-a software library for various nonequispaced fast fourier transforms, ACM Transactions on Mathematical Software (TOMS), vol.36, issue.4, p.19, 2009. ,
A fast wavelet-based reconstruction method for magnetic resonance imaging, IEEE transactions on medical imaging, vol.30, issue.9, pp.1649-1660, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-01813870
A wavelet-based regularized reconstruction algorithm for sense parallel mri with applications to neuroimaging, Medical image analysis, vol.15, issue.2, pp.185-201, 2011. ,
Gadgetron: An open source framework for medical image reconstruction, Magnetic Resonance in Medicine, vol.69, issue.6, pp.1768-1776 ,
Calibrationless oscar-based image reconstruction in compressed sensing parallel mri, IEEE International Symposium of Biomedical Imaging, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-02101262
Bulletin de la Société mathématique de France 93, pp.273-299, 1965. ,
Handbook of MRI pulse sequences, 2004. ,
On variable density compressive sampling, IEEE Signal Processing Letters, vol.18, issue.10, pp.595-598, 2011. ,
Variable density sampling with continuous trajectories. Application to MRI, SIAM Journal on Imaging Sciences, vol.7, pp.1962-1992, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00908486
On the generation of sampling schemes for Magnetic Resonance Imaging, SIAM Journal on Imaging Sciences, vol.9, issue.4, pp.2039-2072, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01373758
Wavelet-based image deconvolution and reconstruction, Wiley Encyclopedia of Electrical and Electronics Engineering, pp.1-34, 1999. ,
URL : https://hal.archives-ouvertes.fr/hal-01164833
A majorize-minimize memory gradient method for complex-valued inverse problems, Signal Processing, vol.103, pp.285-295, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00829788
Proximal splitting methods in signal processing," in Fixed-point algorithms for inverse problems in science and engineering, pp.185-212, 2011. ,
An iterative thresholding algorithm for linear inverse problems with a sparsity constraint, Communications on Pure and Applied Mathematics: A Journal Issued by the Courant Institute of Mathematical Sciences, vol.57, issue.11, pp.1413-1457, 2004. ,
A fast iterative shrinkage-thresholding algorithm for linear inverse problems, SIAM journal on imaging sciences, vol.2, issue.1, pp.183-202, 2009. ,
Exact worst-case performance of first-order methods for composite convex optimization, SIAM Journal on Optimization, vol.27, issue.3, pp.1283-1313, 2017. ,
Stochastic approximations and perturbations in forward-backward splitting for monotone operators, Pure and Applied Functional Analysis, vol.1, issue.1, pp.13-37, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01380000
On the douglasrachford splitting method and the proximal point algorithm for maximal monotone operators, Mathematical Programming, vol.55, issue.1-3, pp.293-318, 1992. ,
A first-order primal-dual algorithm for convex problems with applications to imaging, Journal of mathematical imaging and vision, vol.40, issue.1, pp.120-145, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00490826
A primal-dual splitting method for convex optimization involving Lipschitzian, proximable and linear composite terms, Journal of Optimization Theory and Applications, vol.158, issue.2, pp.460-479, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00609728
A splitting algorithm for dual monotone inclusions involving cocoercive operators, Advances in Computational Mathematics, vol.38, pp.667-681, 2013. ,
Analysis versus synthesis in signal priors, Inverse problems, vol.23, issue.3, p.947, 2007. ,
A primal-dual splitting method for convex optimization involving lipschitzian, proximable and linear composite terms, Journal of Optimization Theory and Applications, vol.158, pp.460-479, 2013. ,
Numerical Recipes 3rd Edition: The Art of Scientific Computing, 2007. ,
Analysis vs synthesis-based regularization for combined compressed sensing and parallel MRI reconstruction at 7 tesla, 26th European Signal Processing Conference, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01800700
The NMR phased array, Magnetic resonance in medicine, vol.16, issue.2, pp.192-225, 1990. ,
ESPIRiT-an eigenvalue approach to autocalibrating parallel MRI: where SENSE meets GRAPPA, Magnetic Resonance in Medicine, vol.71, issue.3, pp.990-1001, 2014. ,
Self-calibrating nonlinear reconstruction algorithms for variable density sampling and parallel reception MRI, 10th IEEE SAM workshop, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01782428
Sparse BLIP: Blind iterative parallel imaging reconstruction using compressed sensing, Magnetic Resonance in Medicine, vol.71, issue.2, pp.645-660, 2014. ,
Low-rank modeling of local k-space neighborhoods (LORAKS) for Constrained MRI, IEEE transactions on Medical Imaging, vol.33, issue.3, pp.668-681, 2014. ,
Calibrationless parallel imaging reconstruction based on structured low-rank matrix completion, Magnetic resonance in medicine, vol.72, issue.4, pp.959-970, 2014. ,
Acceleration of mr parameter mapping using annihilating filter-based low rank hankel matrix (aloha), Magnetic resonance in medicine, vol.76, issue.6, pp.1848-1864, 2016. ,
Calibration-less multi-coil MR image reconstruction, Magnetic Resonance in Medicine, vol.30, issue.7, pp.1032-1045, 2012. ,
Calibrationless parallel MRI using CLEAR, Signals, Systems and Computers (ASILOMAR), 2011 Conference Record of the Forty Fifth Asilomar Conference on, pp.75-79, 2011. ,
Non-cartesian data reconstruction using GRAPPA operator gridding (GROG), Magnetic Resonance in Medicine, vol.58, issue.6, pp.1257-1265, 2007. ,
The ordered weighted l1 norm: Atomic formulation, projections, and algorithms, 2014. ,
An optimal radial profile order based on the golden ratio for time-resolved mri, IEEE transactions on medical imaging, vol.26, issue.1, pp.68-76, 2006. ,
Image quality assessment: from error visibility to structural similarity, IEEE transactions on Image Processing, vol.13, issue.4, pp.600-612, 2004. ,
Estimation of the mean of a multivariate normal distribution, The annals of Statistics, pp.1135-1151, 1981. ,
The elements of statistical learning: data mining, inference and prediction, The Mathematical Intelligencer, vol.27, issue.2, pp.83-85, 2005. ,
Python non-uniform fast Fourier transform (PyNUFFT): An accelerated non-Cartesian MRI package on a heterogeneous platform (CPU/GPU), Journal of Imaging, vol.4, issue.3, p.51, 2018. ,
Deep admm-net for compressive sensing MRI, Advances in neural information processing systems, pp.10-18, 2016. ,
Deep generative adversarial neural networks for compressive sensing MRI, IEEE transactions on medical imaging, vol.38, issue.1, pp.167-179, 2018. ,
Learning a variational network for reconstruction of accelerated MRI data, Magnetic resonance in medicine, vol.79, issue.6, pp.3055-3071, 2018. ,
Image reconstruction by domain-transform manifold learning, Nature, vol.555, issue.7697, p.487, 2018. ,
Iterative reconstruction methods for non-cartesian mri, Proc. ISMRM Workshop on Non-Cartesian MRI, 2007. ,
Array compression for mri with large coil arrays, Magnetic Resonance in Medicine: An Official Journal of the International Society for Magnetic Resonance in Medicine, vol.57, issue.6, pp.1131-1139, 2007. ,
