New interface
Reports (Research report)
Replication Is More Efficient Than You Think
Abstract : This paper revisits replication coupled with checkpointing for fail-stop errors. Replication enables the application to survive many fail-stop errors, thereby allowing for longer checkpointing periods. Previously published works use replication with the no-restart strategy, which never restart failed processors until the application crashes. We introduce the restart strategy where failed processors are restarted after each checkpoint. which may introduce additional overhead during checkpoints but prevents the application configuration from degrading throughout successive checkpointing periods. We show how to compute the optimal checkpointing period for this strategy, which is much larger than the one with no-restart, thereby decreasing I/O pressure. We show through simulations that using the restart strategy significantly decreases the overhead induced by replication, in terms of both total execution time and energy consumption.
Document type :
Complete list of metadata
Cited literature [45 references]  Display  Hide  Download
https://hal.inria.fr/hal-02265925
Contributor : Equipe Roma Connect in order to contact the contributor
Submitted on : Tuesday, August 13, 2019 - 3:53:37 PM
Last modification on : Friday, November 18, 2022 - 9:27:55 AM
Long-term archiving on: : Thursday, January 9, 2020 - 8:26:01 PM
File
rr9278.pdf
Identifiers
  • HAL Id : hal-02265925, version 1
Collections
Citation
Anne Benoit, Thomas Herault, Valentin Le Fèvre, Yves Robert. Replication Is More Efficient Than You Think. [Research Report] RR-9278, Inria - Research Centre Grenoble – Rhône-Alpes. 2019. ⟨hal-02265925⟩
Share
Metrics
Record views
94
Files downloads
169
