The Design Patterns Smalltalk Companion, 1998. ,
, Rationale for the design of the ada programming language
An Empirical Study of the Impact of Two Antipatterns, Blob and Spaghetti Code, on Program Comprehension, p.15, 2011. ,
, European Conference on Software Maintenance and Reengineering, pp.181-190, 2011.
Parameterized duplication in strings: Algorithms and an application to software maintenance, SIAM Journal of Computing, 1997. ,
Smalltalk Best Practice Patterns, 1997. ,
AntiPatterns: Refactoring Software, Architectures, and Projects in Crisis, 1998. ,
Pragmas: Literal messages as powerful method annotations, International Workshop on Smalltalk Technologies IWST'16, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01353592
A language independent approach for detecting duplicated code, Proceedings of 15th IEEE International Conference on Software Maintenance (ICSM'99), pp.109-118, 1999. ,
, A text file containing over 466k english words, pp.2019-2026
Refactoring: Improving the Design of Existing Code, 1999. ,
Smalltalk 80: the Language and its Implementation, 1983. ,
CCFinder: A multi-linguistic token-based code clone detection system for large scale source code, IEEE Transactions on Software Engineering, vol.28, issue.6, pp.654-670, 2002. ,
A scenario based approach for refactoring duplicated code in object oriented systems, 2001. ,
Patterns and antipatterns, Journal of Object-Oriented Programming, 1995. ,
Clean code: a handbook of agile software craftsmanship. Pearson Education, 2009. ,
Enhancing understandability of objective c programs using naming convention checking framework, Proceedings of the World Congress on Engineering and Computer Science, vol.1, 2018. ,
Code convention adherence in evolving software, 27th IEEE International Conference on Software Maintenance (ICSM), pp.504-507, 2011. ,
Maintainability and source code conventions: An analysis of open source projects, Tech. Rep. TR11, vol.6, 2011. ,
A survey on software smells, Journal of Systems and Software, 2018. ,
Refactoring for Software Design Smells: Managing Technical Debt, 2014. ,
Renraku: The one static analysis model to rule them all, Proceedings of the 12th Edition of the International Workshop on Smalltalk Technologies, IWST '17, vol.13, pp.1-13, 2017. ,
On the detection of test smells: A metricsbased approach for general fixture and eager test, Transactions on Software Engineering, vol.33, issue.12, pp.800-817, 2007. ,
Refactoring test code, Proceedings of the 2nd International Conference on Extreme Programming and Flexible Processes (XP2001), pp.92-95, 2001. ,
