Surface wave effects on water temperature in the Baltic Sea: simulation with the coupled NEMO-WAM model, Ocean Dyn, vol.66, pp.917-930, 2016. ,
A comparison of langmuir turbulence parameterizations and key wave effects in a numerical model of the north atlantic and arctic oceans, 2019. ,
A potential enstrophy and energy conserving scheme for the shallow water equations, Mon. Weather Rev, vol.109, issue.1, pp.18-36, 1981. ,
Swell and slanting-fetch effects on wind wave growth, J. Phys. Oceanogr, vol.37, issue.4, pp.908-931, 2007. ,
On the interaction of surface waves and upper ocean turbulence, J. Phys. Oceanogr, vol.36, issue.3, pp.551-557, 2006. ,
Observation and estimation of Lagrangian, Stokes and Eulerian currents induced by wind and waves at the sea surface, J. Phys. Oceanogr, vol.39, issue.11, pp.2820-2838, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-00331675
Explicit wave-averaged primitive equations using a generalized lagrangian mean, Ocean Modell, vol.20, issue.1, pp.35-60, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-00129588
Small scale currents have large effects on wind wave heights, J. Geophys. Res, vol.122, issue.C6, pp.4500-4517, 2017. ,
Semi-empirical dissipation source functions for wind-wave models: part I, definition, calibration and validation, J. Phys. Oceanogr, vol.40, issue.9, pp.1917-1941, 2010. ,
Semiempirical dissipation source functions for ocean waves. part i: Definition, calibration, and validation, J. Phys. Oceanogr, vol.40, issue.9, pp.1917-1941, 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-00407184
Comments on "a combined derivation of the integrated and vertically resolved, coupled wave-current equations, J. Phys. Oceanogr, vol.47, issue.9, pp.2377-2385, 2017. ,
Wind-driven internal waves and Langmuir circulations in a numerical ocean model of the southern Baltic Sea, J. Geophys. Res, vol.107, issue.C11, pp.25-26, 2002. ,
Refined source terms in wind wave models with explicit wave breaking prediction. part i: Model framework and validation against field data, Ocean Modell, vol.33, issue.1, pp.177-189, 2010. ,
Modeling spectral dissipation in the evolution of wind waves. part i: Assessment of existing model performance, J. Phys. Oceanogr, vol.24, issue.7, pp.1550-1571, 1994. ,
Impact of partial steps and momentum advection schemes in a global ocean circulation model at eddy-permitting resolution, Ocean Dyn, vol.56, issue.5, pp.543-567, 2006. ,
URL : https://hal.archives-ouvertes.fr/hal-00183611
A global perspective on langmuir turbulence in the ocean surface boundary layer, Geophys. Res. Lett, issue.18, p.39, 2012. ,
On the coupling of wave and three-dimensional circulation models: Choice of theoretical framework, practical implementation and adiabatic tests, Ocean Modell, vol.40, issue.3, pp.260-272, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-01555792
Mixed layer instabilities and restratification, J. Phys. Oceanogr, vol.37, issue.9, pp.2228-2250, 2007. ,
Coupling a spectral wave model with a coupled ocean-ice model. Drakkar meeting, 2019. ,
A stokes drift approximation based on the phillips spectrum, Ocean Modell, vol.100, pp.49-56, 2016. ,
Approximate Stokes Drift Profiles in Deep Water, J. Phys. Oceanogr, vol.44, pp.2433-2445, 2014. ,
Surface Wave Effects in the NEMO Ocean Model: Forced and Coupled Experiments, J. Geophys. Res, 2015. ,
Climatologically significant effects of some approximations in the bulk parameterizations of turbulent air-sea fluxes, J. Phys. Oceanogr, vol.0, issue.0, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01908438
Wind stress on a water surface, Quart. J. Roy. Meteorol. Soc, vol.81, issue.350, pp.639-640, 1955. ,
Effects of Long Waves on Wind-Generated Waves, J. Phys. Oceanogr, vol.30, pp.2246-2256, 2000. ,
URL : https://hal.archives-ouvertes.fr/hal-01307127
Coupled model predictions and observations, Ocean surface waves in Hurricane Ike (2008) and Superstorm Sandy, vol.103, pp.161-176, 2012. ,
ORCA025-WW3-Couvelard etal GMD, 2019. ,
Mixed layer formation and restratification in presence of mesoscale and submesoscale turbulence, Ocean Modell, vol.96, pp.243-253, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01575235
Development and performance of a new version of the OASIS coupler, Geosci. Model Dev, vol.10, pp.3297-3308, 2017. ,
Modeling Wave-Enhanced Turbulence in the Ocean Surface Layer, J. Phys. Oceanogr, vol.24, pp.2546-2559, 1994. ,
Quantifying upper ocean turbulence driven by surface waves, Geophys. Res. Lett, vol.41, issue.1, pp.102-107, 2014. ,
Stratocumulus-capped mixing layers derived from a threedimensional model, Boundary-Layer Meteorol, vol.18, pp.495-527, 1980. ,
The era-interim reanalysis: configuration and performance of the data assimilation system, Quarterly Journal of the Royal Meteorological Society, vol.137, issue.656, pp.553-597, 2011. ,
Impact of the "Symmetric Instability of the Computational Kind" at mesoscale-and submesoscale-permitting resolutions, Ocean Modell, vol.120, pp.18-26, 2017. ,
Bulk parameterization of air-sea fluxes: Updates and verification for the coare algorithm, J. Climate, vol.16, issue.4, pp.571-591, 2003. ,
Impacts of parameterized langmuir turbulence and nonbreaking wave mixing in global climate simulations, J. Climate, vol.27, issue.12, pp.4752-4775, 2014. ,
Parameterization of mixed layer eddies. part i: Theory and diagnosis, Journal of Physical Oceanography, vol.38, issue.6, pp.1145-1165, 2008. ,
Ocean circulation and climate change, Tellus B: Chemical and Physical Meteorology, vol.43, issue.4, pp.82-103, 1991. ,
Computations and parameterizations of the nonlinear energy transfer in a gravity wave spectrum. Part II. Parameterizations of the nonlinear energy transfer for application in wave models, J. Phys. Oceanogr, vol.15, pp.1378-1391, 1985. ,
The passive microwave water cycle product, Remote Sensing Systems (REMSS), p.30, 2009. ,
Fetch-and Duration-Limited Nature of Surface Wave Growth inside Tropical Cyclones: With Applications to Air-Sea Exchange and Remote Sensing*, J. Phys. Oceanogr, vol.46, pp.41-56, 2015. ,
Ocean wave directional spectra and wave-current interaction in the agulhas from the shuttle imaging radar-b synthetic aperture radar, Journal of Geophysical Research: Oceans, vol.93, issue.C12, pp.15389-15401, 1988. ,
MxN Communication and Parallel Interpolation in Community Climate System Model Version 3 Using the Model Coupling Toolkit, The International Journal of High Performance Computing Applications, vol.19, issue.3, pp.293-307, 2005. ,
Progress in ocean wave forecasting, J. Comp. Phys, vol.227, issue.7, pp.3572-3594, 2008. ,
Quasi-linear Theory of Wind-Wave Generation Applied to Wave Forecasting, J. Phys. Oceanogr, vol.21, issue.4, pp.1631-1642, 1991. ,
On some consequences of the canonical transformation in the Hamiltonian theory of water waves, JOURNAL OF FLUID MECHANICS, vol.637, pp.1-44, 2009. ,
Dynamics and modelling of ocean waves, 1994. ,
The global climatology of an interannually varying air-sea flux data set, Clim. Dyn, vol.33, pp.341-364, 2009. ,
Wave effects in global ocean modeling: parametrizations vs. forcing from a wave model, Ocean Dyn, vol.68, pp.1739-1758, 2018. ,
A conservative leap-frog time stepping method, Oceanogr. Meteorol, vol.30, pp.88-94, 2009. ,
A simplified atmospheric boundary layer model for an improved representation of air-sea interactions in eddying oceanic models. Geosci. Model Dev, 2019. ,
Statistical models of global langmuir mixing, Oceanogr. Meteorol, vol.113, pp.95-114, 2017. ,
Langmuir mixing effects on global climate: Wavewatch iii in cesm, Oceanogr. Meteorol, vol.103, pp.145-160, 2016. ,
Choice of an advection scheme for biogeochemical models, Geophys. Res. Lett, vol.28, issue.19, pp.3725-3728, 2001. ,
NEMO ocean engine, Note du Pole de modélisation No. 27. Institut Pierre-Simon Laplace (IPSL), 2012. ,
Wave refraction by warm core rings, Journal of Geophysical Research: Oceans, vol.90, issue.C4, pp.7153-7162, 1985. ,
An asymptotic theory for the interaction of waves and currents in coastal waters, J. Fluid Mech, vol.511, pp.135-178, 2004. ,
Parameterization of Langmuir Circulation in the Ocean Mixed Layer Model Using LES and Its Application to the OGCM, J. Phys. Oceanogr, vol.46, pp.57-78, 2016. ,
On the response of short ocean wave components at fixed wavenumber to ocean current variations, J. Phys. Oceanogr, vol.14, pp.1425-1433, 1984. ,
Generation of langmuir circulation for nonaligned wind stress and the stokes drift, J. Geophys. Res, vol.102, issue.C7, pp.15773-15780, 1997. ,
Drift and mixing under the ocean surface revisited: Stratified conditions and model-data comparisons, J. Geophys. Res, vol.114, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-00389768
A global wave parameter database for geophysical applications. part 2: model validation with improved source term parameterization, Ocean Modelling, vol.70, pp.174-188, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00387604
A global wave parameter database for geophysical applications. Part 1: wave-current-turbulence interaction parameters for the open ocean based on traditional parameterizations, Ocean Modell, vol.25, pp.154-171, 2008. ,
A simple and general subgrid model suitable both for surface layer and free-stream turbulence, Boundary-Layer Meteorol, vol.101, issue.3, pp.375-408, 2001. ,
Impact of sea-state-dependent langmuir turbulence on the ocean response to a tropical cyclone, Monthly Weather Review, vol.144, issue.12, pp.4569-4590, 2016. ,
Modulation of wind work by oceanic current interaction with the atmosphere, J. Phys. Oceanogr, vol.46, issue.6, pp.1685-1704, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01295496
Strong sensitivity of southern ocean carbon uptake and nutrient cycling to wind stirring, Biogeosciences, vol.11, issue.15, pp.4077-4098, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01128483
An accurate polynomial expression for the TEOS-10 equation of state for use in ocean general circulation models, Oceanogr. Meteorol, vol.90, pp.29-43, 2015. ,
The Louvain-La-Neuve sea ice model LIM3.6: global and regional capabilities, Geoscientific Model Development, vol.8, issue.10, pp.2991-3005, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01234098
An ocean large-eddy simulation of langmuir circulations and convection in the surface mixed layer, J. Geophys. Res, vol.100, issue.C5, pp.8501-8522, 1995. ,
Effects of wave-induced forcing on a circulation model of the north sea, Ocean Dynamics, vol.67, issue.1, pp.81-101, 2017. ,
Strong and highly variable push of ocean waves on southern ocean sea ice, Proc. Nat. Acad. Sci, vol.115, issue.23, pp.5861-5865, 2018. ,
Understanding stokes forces in the wave-averaged equations, J. Geophys. Res, vol.121, issue.5, pp.3579-3596, 2016. ,
User manual and system documentation of WAVE-WATCH III R version 5.16. Tech. Note 329. NOAA/NWS/NCEP/MMAB, 1972. ,
Development and Implementation of Wind-Generated Ocean Surface Wave Modelsat NCEP, Wea Forecasting, vol.17, pp.311-333, 2002. ,
Wave-current interaction in an oceanic circulation model with a vortex-force formalism: Application to the surf zone, Ocean Modell, vol.34, issue.1, pp.16-35, 2010. ,
, Algorithms for computation of fundamental property of sea water 44, UNESCO, 1983.
The OASIS3 coupler: a European climate modelling community software, Geoscientific Model Development Discussions, vol.5, pp.2139-2178, 2012. ,
The form and orientation of langmuir cells for misaligned winds and waves, J. Geophys. Res, vol.117, issue.C5, 2012. ,
