Surface Expressions of Subsurface Sediment Mobilization Rooted into a Gas Hydrate-Rich Cryosphere on Mars - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Scientific Reports Année : 2019
We report on evidence for fluid circulation in the upper crust of Mars, which could create environments favorable for life and its development. We investigate the nature of the thumbprint terrains covering part of Arcadia planitia in the Martian northern hemisphere. our analytic procedure allowed us to (i) hypothesise a potential relationship between these thumbprint terrains and an inferred underground fracture network that extends to where the clathrate-rich cryosphere contacts with the underlying hydrosphere; (ii) support the hypothesis that these thumbprint terrains are made of fine grained loosely packed materials erupted from deep beneath the subsurface mobilized by water; and (iii) date the thumbprint terrains of Arcadia Planitia to ~370 Ma. We conclude that the study area is an area worthy of astrobiological investigation, bringing water and fine grained sediment from depth to the surface for investigation.
Planétologie
HAL_DeToffoli_etal_SciReports_2019.pdf (2.04 Mo) Télécharger le fichier
hal-02268388 , version 1 (20-08-2019)
Barbara de Toffoli, Riccardo Pozzobon, Matteo Massironi, Francesco Mazzarini, Susan J. Conway, et al.. Surface Expressions of Subsurface Sediment Mobilization Rooted into a Gas Hydrate-Rich Cryosphere on Mars. Scientific Reports, 2019, 9, pp.8603. ⟨10.1038/s41598-019-45057-7⟩. ⟨hal-02268388⟩
72 Consultations
37 Téléchargements
