Each H 1/2 -stable projection yields convergence and quasi-optimality of adaptive FEM with inhomogeneous Dirichlet data in R d, ESAIM Math. Model. Numer. Anal, vol.47, pp.1207-1235, 2013. ,
The h-p version of the finite element method with quasi-uniform meshes, RAIRO Modél. Math. Anal. Numér, vol.21, pp.199-238, 1987. ,
Local flux reconstructions for standard finite element methods on triangular meshes, SIAM J. Numer. Anal, vol.54, pp.2684-2706, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01581283
A local regularization operator for triangular and quadrilateral finite elements, SIAM J. Numer. Anal, vol.35, pp.1893-1916, 1998. ,
URL : https://hal.archives-ouvertes.fr/hal-01793439
Quelques propriétés d'approximation deséléments finis de Nédélec, applicationà l'analyse a posteriori, C. R. Math. Acad. Sci. Paris, vol.344, pp.461-466, 2007. ,
A new H(div)-conforming p-interpolation operator in two dimensions, ESAIM Math. Model. Numer. Anal, vol.45, pp.255-275, 2011. ,
Mixed finite element methods and applications, vol.44, 2013. ,
Equilibrated residual error estimates are p-robust, Comput. Methods Appl. Mech. Engrg, vol.198, pp.1189-1197, 2009. ,
Equilibrated residual error estimator for edge elements, Math. Comp, vol.77, pp.651-672, 2008. ,
Optimal error estimate for the div least-squares method with data f ? L 2 and application to nonlinear problems, SIAM J. Numer. Anal, vol.47, pp.4098-4111, 2010. ,
Convergence and optimality of hp-AFEM, Numer. Math, vol.135, pp.1073-1119, 2017. ,
Comparison results of finite element methods for the Poisson model problem, SIAM J. Numer. Anal, vol.50, pp.2803-2823, 2012. ,
Medius analysis and comparison results for first-order finite element methods in linear elasticity, IMA J. Numer. Anal, vol.35, pp.1591-1621, 2015. ,
Smoothed projections in finite element exterior calculus, Math. Comp, vol.77, pp.813-829, 2008. ,
Approximation by finite element functions using local regularization, RAIRO Anal. Numer, vol.9, issue.2, pp.77-84, 1975. ,
On Bogovski? and regularized Poincaré integral operators for de Rham complexes on Lipschitz domains, Math. Z, vol.265, pp.297-320, 2010. ,
Polynomial exact sequences and projection-based interpolation with application to Maxwell equations, pp. x+235. Lectures given at the C.I.M.E. Summer School, vol.1939, 2006. ,
H 1 , H(curl) and H(div)-conforming projection-based interpolation in three dimensions. Quasi-optimal p-interpolation estimates, Comput. Methods Appl. Mech. Engrg, vol.194, pp.267-296, 2005. ,
, J. Polynomial extension operators. Part I. SIAM J. Numer. Anal, vol.46, pp.3006-3031, 2008.
Polynomial extension operators. Part II, SIAM J. Numer. Anal, vol.47, pp.3293-3324, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-00163158
, J. Polynomial extension operators. Part III. Math. Comp, vol.81, pp.1289-1326, 2012.
Explicit error bounds in a conforming finite element method, Math. Comp, vol.68, pp.1379-1396, 1999. ,
hp-adaptation driven by polynomial-degree-robust a posteriori error estimates for elliptic problems, SIAM J. Sci. Comput, vol.38, pp.3220-3246, 2016. ,
Mollification in strongly Lipschitz domains with application to continuous and discrete de Rham complexes, Comput. Methods Appl. Math, vol.16, pp.51-75, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01192941
Finite element quasi-interpolation and best approximation, ESAIM Math. Model. Numer. Anal, vol.51, pp.1367-1385, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01155412
Quasi-optimal nonconforming approximation of elliptic PDEs with contrasted coefficients and minimal regularity, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01964299
Discrete p-robust H(div)-liftings and a posteriori estimates for elliptic problems with H ?1 source terms, Calcolo, vol.54, pp.1009-1025, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01377007
Adaptive inexact Newton methods with a posteriori stopping criteria for nonlinear diffusion PDEs, SIAM J. Sci. Comput, vol.35, pp.1761-1791, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00681422
Polynomial-degree-robust a posteriori estimates in a unified setting for conforming, nonconforming, discontinuous Galerkin, and mixed discretizations, SIAM J. Numer. Anal, vol.53, pp.1058-1081, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-00921583
Stable broken H 1 and H(div) polynomial extensions for polynomialdegree-robust potential and flux reconstruction in three space dimensions, Math. Comp, vol.89, pp.551-594, 2020. ,
Local bounded cochain projections, Math. Comp, vol.83, pp.2631-2656, 2014. ,
A new error analysis for discontinuous finite element methods for linear elliptic problems, Math. Comp, vol.79, pp.2169-2189, 2010. ,
A comment on least-squares finite element methods with minimum regularity assumptions, Int. J. Numer. Anal. Model, vol.10, pp.899-903, 2013. ,
Smoothed projections and mixed boundary conditions, Math. Comp, vol.88, pp.607-635, 2019. ,
A local a posteriori error estimator based on equilibrated fluxes, SIAM J. Numer. Anal, vol.42, pp.1394-1414, 2004. ,
URL : https://hal.archives-ouvertes.fr/inria-00343040
On commuting p-version projection-based interpolation on tetrahedra, Math. Comp, vol.89, pp.45-87, 2020. ,
Mixed finite elements in R 3, Numer. Math, vol.35, pp.315-341, 1980. ,
A posteriori error estimates for the electric field integral equation on polyhedra, Contributions to partial differential equations and applications, vol.47, pp.371-394, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-01090944
Least-squares mixed finite elements for second-order elliptic problems, SIAM J. Numer. Anal, vol.31, pp.1368-1377, 1994. ,
A mixed finite element method for 2nd order elliptic problems, Mathematical aspects of finite element methods (Proc. Conf., Consiglio Naz. delle Ricerche, vol.606, pp.292-315, 1975. ,
Mixed and hybrid methods, Handbook of Numerical Analysis, vol.II, pp.523-639, 1991. ,
URL : https://hal.archives-ouvertes.fr/inria-00075815
Commuting quasi-interpolation operators for mixed finite elements, 2001. ,
A multilevel decomposition result in H(curl), Multigrid, Multilevel and Multiscale Methods (EMG 2005, 2005. ,
Finite element interpolation of nonsmooth functions satisfying boundary conditions, Math. Comp, vol.54, pp.483-493, 1990. ,
Approximating gradients with continuous piecewise polynomial functions, Found. Comput. Math, vol.16, pp.723-750, 2016. ,
A posteriori error estimation techniques for finite element methods. Numerical Mathematics and Scientific Computation, 2013. ,
