High order methods for CFD, Encyclopedia of Computational Mechanics, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01444075
High order fluctuation schemes on triangular meshes, Journal of Scientific Computing, vol.19, issue.1, pp.3-36, 2003. ,
Unified analysis of discontinuous galerkin methods for elliptic problems, SIAM Journal on Numerical Analysis, vol.39, issue.5, pp.1749-1779, 2002. ,
An interior penalty finite element method with discontinuous elements, SIAM journal on numerical analysis, vol.19, issue.4, pp.742-760, 1982. ,
Stabilized continuous and discontinuous galerkin techniques for darcy flow, Computer Methods in Applied Mechanics and Engineering, vol.199, issue.25, pp.1654-1667, 2010. ,
Anisotropic boundary layer mesh generation for immersed complex geometries, Engineering with Computers, vol.33, issue.2, pp.249-260, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01521734
Ghost penalty, Comptes Rendus Mathematique, vol.348, pp.1217-1220, 2010. ,
URL : https://hal.archives-ouvertes.fr/inria-00543248
Fictitious domain methods using cut elements: Iii. a stabilized nitsche method for stokes' problem, ESAIM: Mathematical Modelling and Numerical Analysis, vol.48, issue.3, pp.859-874, 2014. ,
Compact third-order multidimensional upwind scheme for navier-stokes simulations, Theoret Comput Fluid Dynamics, vol.15, pp.373-401, 2002. ,
Euler calculations for multielement airfoils using cartesian grids, AIAA Journal, vol.24, issue.3, pp.353-358, 1986. ,
A hybridizable discontinuous galerkin method for steady-state convectiondiffusion-reaction problems, SIAM Journal on Scientific Computing, vol.31, issue.5, pp.3827-3846, 2009. ,
, Discontinuous Galerkin Methods: Theory, Computation and Applications, 2000.
Interior penalty procedures for elliptic and parabolic galerkin methods, Computing Methods in Applied Sciences, pp.207-216, 1976. ,
Self-adaptive finite element simulation of miscible displacement in porous media, Computer Methods in Applied Mechanics and Engineering, vol.47, issue.1, pp.131-159, 1984. ,
The finite cell method for three-dimensional problems of solid mechanics, Computer methods in applied mechanics and engineering, vol.197, issue.45, pp.3768-3782, 2008. ,
Theory and practice of finite elements, Applied Mathematical Sciences, vol.159, 2004. ,
An adaptive, formally second order accurate version of the immersed boundary method, Journal of Computational Physics, vol.223, issue.1, pp.10-49, 2007. ,
On the order of accuracy of the immersed boundary method: Higher order convergence rates for sufficiently smooth problems, Journal of Computational Physics, vol.208, issue.1, pp.75-105, 2005. ,
Immersed stress method for fluid-structure interaction using anisotropic mesh adaptation, International Journal for Numerical Methods in Engineering, vol.94, issue.9, pp.805-825, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00815641
An unfitted finite element method, based on nitsche's method, for elliptic interface problems, Computer Methods in Applied Mechanics and Engineering, vol.191, issue.47, pp.5537-5552, 2002. ,
URL : https://hal.archives-ouvertes.fr/hal-01352903
A high-order, fully coupled, upwind, compact discontinuous galerkin method for modeling of viscous fingering in compressible porous media, Computer Methods in Applied Mechanics and Engineering, vol.263, pp.169-187, 2013. ,
A stabilized mixed discontinuous galerkin method for darcy flow, Computer Methods in Applied Mechanics and Engineering, vol.195, issue.25, pp.3347-3381, 2006. ,
A multiscale discontinuous galerkin method with the computational structure of a continuous galerkin method, Computer Methods in Applied Mechanics and Engineering, vol.195, issue.19, pp.2761-2787, 2006. ,
A representation of curved boundaries for the solution of the navier-stokes equations on a staggered three-dimensional cartesian grid, Journal of Computational Physics, vol.184, issue.1, pp.1-36, 2003. ,
A locally conservative enriched galerkin approximation and efficient solver for elliptic and parabolic problems, SIAM Journal on Scientific Computing, vol.38, issue.3, pp.1404-1429, 2016. ,
Immersed interface methods for stokes flow with elastic boundaries or surface tension, SIAM Journal on Scientific Computing, vol.18, issue.3, pp.709-735, 1997. ,
A high-order immersed interface method for simulating unsteady incompressible flows on irregular domains, Journal of Computational Physics, vol.204, issue.1, pp.157-192, 2005. ,
The shifted boundary method for embedded domain computations. part i: Poisson and stokes problems, Journal of Computational Physics, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01793474
The shifted boundary method for embedded domain computations. part ii: Linear advection-diffusion and incompressible navier-stokes equations, Journal of Computational Physics, 2018. ,
A stabilized mixed finite element method for darcy flow, Computer Methods in Applied Mechanics and Engineering, vol.191, issue.39, pp.4341-4370, 2002. ,
Improved second-order hyperbolic residual-distribution scheme and its extension to third-order on arbitrary triangular grids, Journal of Computational Physics, vol.300, pp.455-491, 2015. ,
Efficient high-order discontinuous galerkin schemes with first-order hyperbolic advection-diffusion system approach, Journal of Computational Physics, vol.321, pp.729-754, 2016. ,
A first-order hyperbolic system approach for dispersion, Journal of Computational Physics, vol.321, pp.593-605, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01390677
Immersed boundary methods, Annual Review of Fluid Mechanics, vol.37, issue.1, pp.239-261, 2005. ,
Robust and accurate viscous discretization via upwind scheme -i: Basic principle, Computers & Fluids, vol.49, issue.1, pp.62-86, 2011. ,
On hyperbolic method for diffusion with discontinuous coefficients, Journal of Computational Physics, vol.367, pp.102-108, 2018. ,
Uber ein Variationsprinzip zur Losung Dirichlet-Problemen bei Verwendung von Teilraumen, die keinen Randbedingungen unteworfen sind, Abh. Math. Sem. Univ, vol.36, pp.9-15, 1971. ,
An adaptive, residual based, splitting approach for the penalized navier stokes equations, Computer Methods in Applied Mechanics and Engineering, vol.303, pp.208-230, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01403209
, Finite cell method. Computational Mechanics, vol.41, issue.1, pp.121-133, 2007.
Flow patterns around heart valves: A numerical method, Journal of Computational Physics, vol.10, issue.2, pp.252-271, 1972. ,
Universal meshes: A method for triangulating planar curved domains immersed in nonconforming meshes, International Journal for Numerical Methods in Engineering, vol.98, issue.4, pp.236-264, 2014. ,
Triangular mesh methods for the neutron transport equation, vol.10, 1973. ,
A face-oriented stabilized nitsche-type extended variational multiscale method for incompressible two-phase flow, International Journal for Numerical Methods in Engineering, vol.104, issue.7, pp.721-748, 2015. ,
A new face-oriented stabilized xfem approach for 2d and 3d incompressible navier-stokes equations, Computer Methods in Applied Mechanics and Engineering, vol.276, pp.233-265, 2014. ,
A discontinuous galerkin method for gravity-driven viscous fingering instabilities in porous media, Journal of Computational Physics, vol.233, pp.373-399, 2013. ,
The shifted boundary method for hyperbolic systems: Embedded domain computations of linear waves and shallow water flows, Journal of Computational Physics, vol.369, pp.45-79, 2018. ,
Immersed boundary methods for simulating fluid-structure interaction, Progress in Aerospace Sciences, vol.65, pp.1-21, 2014. ,
Elafint: A mixed eulerian-lagrangian method for fluid flows with complex and moving boundaries, International Journal for Numerical Methods in Fluids, vol.22, issue.8, pp.691-712, 1996. ,
Dual-scale galerkin methods for darcy flow, Journal of Computational Physics, vol.354, pp.111-134, 2018. ,
An elliptic collocation-finite element method with interior penalties, SIAM Journal on Numerical Analysis, vol.15, issue.1, pp.152-161, 1978. ,
