Testbed Evaluation of Optimized REACT over Multi-hop Paths
REACT is a distributed resource allocation protocol that computes a max-min allocation of airtime for mesh networks. The allocation adapts automatically to changes in local traffic load and in local network views. SALT, a new contention window tuning algorithm, ensures that each node secures the airtime allocated to it by REACT. REACT and SALT are extended to the multi-hop flow scenario with the introduction of a new airtime reservation algorithm. With a reservation in place, multi-hop TCP flows show increased throughput when running over SALT and REACT compared to running over 802.11 DCF. All results are obtained from experimentation on the w-iLab.t wireless network testbed in Belgium.
