A. Capone, C. Cascone, A. Q. Nguyen, and B. Sansò, Detour planning for fast and reliable failure recovery in SDN with openstate, 2014.
D. E. Comer, Internetworking with TCP/IP, volume I, 1995.
C. Filsfils, N. K. Nainar, C. Pignataro, J. C. Cardona, and P. Francois, The segment routing architecture, IEEE Global Communications Conference (GLOBECOM), pp.1-6, 2015.
K. Foerster, S. Schmid, and S. Vissicchio, Survey of consistent network updates, 2016.
K. T. Frster, R. Mahajan, and R. Wattenhofer, Consistent updates in software defined networks: On dependencies, loop freedom, and blackholes, pp.1-9, 2016.
F. Hao, M. Kodialam, and T. V. Lakshman, Optimizing restoration with segment routing, IEEE INFOCOM 2016 -The 35th Annual IEEE International Conference on Computer Communications, pp.1-9, 2016.
N. Kitsuwan, D. B. Payne, and M. Ruffini, A novel protection design for openflowbased networks, The 16th International Conference on Transparent Optical Networks (ICTON), pp.1-5, 2014.
H. Liaoruo, S. Qingguo, and S. Wenjuan, A source routing based link protection method for link failure in sdn, The 2nd IEEE International Conference on Computer and Communications (ICCC), pp.2588-2594, 2016.
Y. D. Lin, H. Y. Teng, C. R. Hsu, C. C. Liao, and Y. C. Lai, Fast failover and switchover for link failures and congestion in software defined networks, IEEE International Conference on Communications (ICC), pp.1-6, 2016.
R. M. Ramos, M. Martinello, and C. E. Rothenberg, Slickflow: Resilient source routing in data center networks unlocked by openflow, The 38th Annual IEEE Conference on Local Computer Networks, pp.606-613, 2013.
A. Sgambelluri, A. Giorgetti, F. Cugini, F. Paolucci, and P. Castoldi, Openflowbased segment protection in ethernet networks, IEEE/OSA Journal of Optical Communications and Networking, vol.5, issue.9, pp.1066-1075, 2013.
S. Sharma, D. Staessens, D. Colle, M. Pickavet, and P. Demeester, Enabling fast failure recovery in openflow networks, The 8th International Workshop on the Design of Reliable Communication Networks (DRCN), pp.164-171, 2011.
S. Sharma, D. Staessens, D. Colle, M. Pickavet, and P. Demeester, Openflow: Meeting carrier-grade recovery requirements, Computer Communications, vol.36, issue.6, pp.656-665, 2013.
M. Soliman, B. Nandy, I. Lambadaris, and P. Ashwood-smith, Exploring source routed forwarding in sdn-based wans, IEEE International Conference on Communications (ICC), pp.3070-3075, 2014.
