Toward Resilient Smart Grid Communications Using Distributed SDN with ML-Based Anomaly Detection - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Allen Starke
  • Fonction : Auteur
  • PersonId : 1052635
Janise Mcnair
  • Fonction : Auteur
  • PersonId : 1052636
Rodrigo Trevizan
  • Fonction : Auteur
  • PersonId : 1052637
Arturo Bretas
Joshua Peeples
  • Fonction : Auteur
  • PersonId : 1052639
Alina Zare
  • Fonction : Auteur
  • PersonId : 1052640
Next generation “Smart” systems, including cyber-physical systems like smart grid and Internet-of-Things, integrate control, communication and computation to achieve stability, efficiency and robustness of physical processes. While a great amount of research has gone towards building these systems, security in the form of resilient and fault-tolerant communications for smart grid systems is still immature. In this paper, we propose a hybrid, distributed and decentralized (HDD) SDN architecture for resilient Smart Systems. It provides a redundant controller design for fault-tolerance and fail-over operation, as well as parallel execution of multiple anomaly detection algorithms. Using the k-means clustering algorithm from the machine learning literature, it is shown that k-means can be used to produce a high accuracy (96.9%) of identifying anomalies within normal traffic. Furthermore, incremental k-means produces a slightly lower accuracy (95.6%) but demonstrated an increased speed with respect to k-means and fewer CPU and memory resources needed, indicating a possibility for scaling the system to much larger networks.
470666_1_En_7_Chapter.pdf (1.53 Mo) Télécharger le fichier
hal-02269741 , version 1 (23-08-2019)
Paternité
Allen Starke, Janise Mcnair, Rodrigo Trevizan, Arturo Bretas, Joshua Peeples, et al.. Toward Resilient Smart Grid Communications Using Distributed SDN with ML-Based Anomaly Detection. International Conference on Wired/Wireless Internet Communication (WWIC), Jun 2018, Boston, MA, United States. pp.83-94, ⟨10.1007/978-3-030-02931-9_7⟩. ⟨hal-02269741⟩
89 Consultations
118 Téléchargements
