Reactions of sulfur dioxide with oxidized polyolefins, Polym. Degrad. Stab, vol.15, pp.67-79, 1986. ,
Influence of three ageing types (thermal oxidation, radiochemical and hydrolytic ageing) on the structure and gas transport properties of epoxy-amine networks, Polym. Degrad. Stab, vol.72, pp.447-458, 2001. ,
Radiochemical ageing of an amine cured epoxy network. Part II: kinetic modelling, Polymer, vol.46, pp.237-242, 2005. ,
URL : https://hal.archives-ouvertes.fr/hal-00110957
Advantages and limits of hydroperoxide titration methods in solid polymers, Polym. Photochem, vol.7, pp.409-416, 1986. ,
A study on physicochemical properties of epoxy coating system for nuclear power plants, Nucl. Eng. Des, vol.236, pp.931-937, 2006. ,
Degradation of epoxy resins under high energy electron beam irradiation: radio-oxidation, Polym. Degrad. Stab, vol.92, pp.2190-2197, 2007. ,
Multiscale approach to investigate the radiochemical degradation of epoxy resins under high-energy electron-beam irradiation, J. Polym. Sci.: Polym. Chem, vol.44, pp.865-887, 2006. ,
Thermal (DSC) and chemical (iodometric titration) methods for peroxides measurements in order to monitor drying extent of alkyd resins, Prog. Org. Coat, vol.41, pp.171-176, 2001. ,
High resolution solid-state 13, 2001. ,
, C-NMR study of as-cured and irradiated epoxy resins, Polym. Adv. Technol, vol.12, pp.515-523
A differential scanning calorimetry method to study polymer photoperoxidation, Polym. Test, vol.20, pp.765-768, 2001. ,
Effects of irradiation and design basis accident conditions on thermal properties of epoxy coating system for nuclear power plant, Nucl. Eng. Des, vol.228, pp.47-54, 2004. ,
Hydroperoxide titration by DSC in thermally oxidized polypropylene, Polym. Test, vol.25, pp.829-838, 2006. ,
Effect of structure on water diffusion in polymers, Defect and Diffusion Forum, vol.258, pp.442-446, 2006. ,
URL : https://hal.archives-ouvertes.fr/hal-00282486
