Abstract : User Interface (UI) development is a challenging task as modern UIs are expected to be available across a wide range of diverse platforms while assuring high usability for heterogeneous users. Model-driven engineering principles have been applied in the context of multi-device and cross-device UI development to tackle complexity in development. While previous work related to usability evaluation of model-driven UIs primarily focused on single- and multi-device UIs, an investigation of the usability of model-driven cross-device UIs was not fully covered yet. In this paper, therefore, we present a model-driven UI development (MDUID) approach for cross-device UIs and analyze whether the applied MDUID approach has a positive impact on the usability of the generated UI. To accomplish this, we conduct a usability evaluation based on the generated UI for a cross-channel banking web application. The usability evaluation results provide detailed feedback regarding fulfillment of different usability criteria and enable improvement of involved models as well as model transformations.
https://hal.inria.fr/hal-02270698 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Monday, August 26, 2019 - 11:05:27 AM Last modification on : Monday, August 26, 2019 - 11:13:14 AM Long-term archiving on: : Friday, January 10, 2020 - 10:47:51 PM
Enes yigitbas, Anthony Anjorin, Ivan Jovanovikj, Thomas Kern, Stefan Sauer, et al.. Usability Evaluation of Model-Driven Cross-Device Web User Interfaces. 7th International Conference on Human-Centred Software Engineering (HCSE), Sep 2018, Sophia Antipolis, France. pp.231-247, ⟨10.1007/978-3-030-05909-5_14⟩. ⟨hal-02270698⟩
