Journal articles
Partial tensor decomposition for decoupling isogeometric Galerkin discretizations
Abstract : System matrix assembly for isogeometric (i.e., spline-based) discretizations of partial differential equations is more challenging than for classical finite elements, due to the increased polynomial degrees and the larger (and hence more overlapping) supports of the basis functions. The global tensor-product structure of the discrete spaces employed in isogeometric analysis can be exploited to accelerate the computations, using sum factorization, precomputed look-up tables, and tensor decomposition. We generalize the third approach by considering partial tensor decompositions. We show that the resulting new method preserves the global discretization error and that its computational complexity compares favorably to the existing approaches. Moreover, the numerical realization simplifies considerably since it relies on standard techniques from numerical linear algebra.
Complete list of metadata
Cited literature [35 references]  Display  Hide  Download
https://hal.inria.fr/hal-02271800
Contributor : Angelos Mantzaflaris Connect in order to contact the contributor
Submitted on : Tuesday, August 27, 2019 - 11:24:01 AM
Last modification on : Friday, July 8, 2022 - 10:06:32 AM
Partialtensordecomp3d.pdf
Identifiers
Collections
Citation
Felix Scholz, Angelos Mantzaflaris, Bert Jüttler. Partial tensor decomposition for decoupling isogeometric Galerkin discretizations. Computer Methods in Applied Mechanics and Engineering, Elsevier, 2018, 336, pp.485-506. ⟨10.1016/j.cma.2018.03.026⟩. ⟨hal-02271800⟩
Share
Metrics
Record views
54
Files downloads
110
