Isogeometric analysis using T-Splines, Comput. Methods Appl. Mech. Engrg, vol.199, pp.229-263, 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-01517950
Analysis-Suitable T-splines are Dual-Compatible, Comput. Methods Appl. Mech. Engrg, pp.42-51, 2012. ,
Analysis-suitable T-splines of arbitrary degree: definition, linear independence and approximation properties, Math. Models Methods Appl. Sci, vol.23, pp.1979-2003, 2013. ,
Some properties of LR-splines, Comput. Aided Geom. Design, vol.30, pp.778-794, 2013. ,
A Hierarchical Construction of LR Meshes in 2D, 2015. ,
Adaptively refined multi-patch B-splines with enhanced smothness, G+S Report, issue.26, 2015. ,
Adaptive isogeometric methods with hierarchical splines: error estimator and convergence, Math. Models Methods Appl. Sci, 2015. ,
BPX-preconditioning for isogeometric analysis, Comput. Methods Appl. Mech. Engrg, vol.265, pp.63-70, 2013. ,
Isogeometric Analysis: Toward Integration of CAD and FEA, 2009. ,
Studies of refinement and continuity in isogeometric structural analysis, Comput. Methods Appl. Mech. Engrg, vol.196, pp.4160-4183, 2007. ,
Polynomial splines over hierarchical T-meshes, Graph. Models, vol.70, pp.76-86, 2008. ,
Polynomial splines over locally refined box-partitions, Comput. Aided Geom. Design, vol.30, pp.331-356, 2013. ,
Adaptive isogeometric analysis by local h-refinement with T-splines, Comput. Methods Appl. Mech. Engrg, vol.199, issue.5-8, pp.264-275, 2010. ,
Hierarchical T-splines: Analysis-suitability, Bézier extraction, and application as an adaptive basis for isogeometric analysis, Comput. Methods Appl. Mech. Engrg, vol.284, pp.1-20, 2015. ,
Planar domain parameterization with THB-splines, Comput. Aided Geom. Design, pp.95-108, 2015. ,
Hierarchical B-spline refinement, Comput. Graphics, vol.22, pp.205-212, 1988. ,
Bases and dimensions of bivariate hierarchical tensor-product splines, J. Comput. Appl. Math, vol.239, pp.162-178, 2013. ,
THB-splines: The truncated basis for hierarchical splines, Comput. Aided Geom. Design, vol.29, issue.7, pp.485-498, 2012. ,
Strongly stable bases for adaptively refined multilevel spline spaces, Adv. Comp. Math, vol.40, issue.2, pp.459-490, 2014. ,
Interpolating and approximating scattered 3D-data with hierarchical tensor product B-splines, Surface Fitting and Multiresolution Methods, pp.163-172, 1997. ,
Multigrid methods for isogeometric analysis with THB-splines, 2015. ,
Isogeometric analysis: CAD, finite elements, NURBS, exact geometry and mesh refinement, Comput. Methods Appl. Mech. Engrg, vol.194, pp.4135-4195, 2005. ,
URL : https://hal.archives-ouvertes.fr/hal-01513346
Isogeometric analysis using LR B-splines, Comput. Methods Appl. Mech. Engrg, vol.269, pp.471-514, 2014. ,
On the similarities and differences between Classical Hierarchical, Truncated Hierarchical and LR B-splines, Comput. Methods Appl. Mech. Engrg, vol.291, pp.64-101, 2015. ,
A numerical study of a posteriori error estimators for convection-diffusion equations, Comput. Methods Appl. Mech. Engrg, vol.190, pp.757-781, 2000. ,
, Geometry + Simulation Modules: Implementing Isogeometric Analysis. PAMM, vol.14, pp.961-962, 2014.
Algorithms and data structures for truncated hierarchical B-splines, Mathematical Methods for Curves and Surfaces, vol.8177, pp.304-323, 2014. ,
Adaptive CAD model (re-)construction with THB-splines, Graph. Models, vol.76, pp.273-288, 2014. ,
Adaptive and linearly independent multilevel B-splines, Surface Fitting and Multiresolution Methods, pp.209-218, 1997. ,
Surface modeling with polynomial splines over hierarchical T-meshes, Visual Comput, vol.23, pp.1027-1033, 2007. ,
On linear independence of T-spline blending functions, Comput. Aided Geom. Design, vol.29, pp.63-76, 2012. ,
On the completeness of hierarchical tensor-product B-splines, J. Comput. Appl. Math, vol.271, pp.53-70, 2014. ,
Analysis-suitable adaptive T-mesh refinement with linear complexity, Comput. Aided Geom. Design, vol.34, pp.50-66, 2015. ,
Isogeometric analysis using polynomial splines over hierarchical T-meshes for two-dimensional elastic solids, Comput. Methods Appl. Mech. Engrg, vol.200, pp.1892-1908, 2011. ,
The NURBS book, 1997. ,
Finite element methods for fluids, 1989. ,
Iterative Methods for Sparse Linear Systems, 2003. ,
An isogeometric design-through-analysis methodology based on adaptive hierarchical refinement of NURBS, immersed boundary methods, and T-spline CAD surfaces, Comput. Methods Appl. Mech. Engrg, pp.116-150, 2012. ,
T-spline simplification and local refinement, ACM Trans. Graphics, vol.23, pp.276-283, 2004. ,
, ACM Trans. Graphics, vol.22, pp.477-484, 2003.
Locally refined spline surfaces for representation of terrain data, Comput. Graphics, vol.49, pp.58-68, 2015. ,
Effortless quasi-interpolation in hierarchical spaces, Numer. Math, 2015. ,
A hierarchical approach to adaptive local refinement in isogeometric analysis, Computer Methods in Applied Mechanics and Engineering, pp.3554-3567, 2011. ,
Adaptive isogeometric analysis using rational PHT-splines, Computer-Aided Design, vol.43, issue.11, pp.1438-1448, 2011. ,
Conversion between T-splines and hierarchical B-splines, Computer Graphics and Imaging, pp.8-13, 2005. ,
Truncated hierarchical Catmull-Clark subdivision with local refinement, Comput. Methods Appl. Mech. Engrg, vol.291, pp.1-20, 2015. ,
Hierarchical bases of spline spaces with highest order smoothness over hierarchical T-subdivisions, Comput. Aided Geom. Design, vol.29, pp.499-509, 2012. ,
Adaptively refined multilevel spline spaces from generating systems, Comput. Aided Geom. Design, vol.31, pp.545-566, 2014. ,
On the linear independence of (truncated) hierarchical subdivision splines, 2014. ,
