T. Hughes, J. Cottrell, and Y. Bazilevs, Isogeometric analysis: CAD, finite elements, NURBS, exact geometry and mesh refinement, Computer Methods in Applied Mechanics and Engineering, vol.194, pp.4135-4195, 2005.
URL : https://hal.archives-ouvertes.fr/hal-01513346
J. A. Cottrell, T. J. Hughes, and Y. Bazilevs, Isogeometric Analysis: Toward Integration of CAD and FEA, 2009.
P. Antolin, A. Buffa, F. Calabro, M. Martinelli, and G. Sangalli, Efficient matrix computation for tensor-product isogeometric analysis: The use of sum factorization, Computer Methods in Applied Mechanics and Engineering, vol.285, pp.817-828, 2015.
T. Hughes, A. Reali, and G. Sangalli, Efficient quadrature for NURBS-based isogeometric analysis, Computer Methods in Applied Mechanics and Engineering, vol.199, issue.5-8, pp.301-313, 2010.
A. Mantzaflaris and B. Jüttler, Integration by Interpolation and Look-up for Galerkin-based Isogeometric Analysis, Computer Methods in Applied Mechanics and Engineering, vol.284, pp.373-400, 2015.
URL : https://hal.archives-ouvertes.fr/hal-01011281
A. Mantzaflaris, B. Jüttler, B. Khoromskij, U. Langer, and ;. Nfn-g+s, Matrix Generation in Isogeometric Analysis by Low Rank Tensor Approximation, 2014.
URL : https://hal.archives-ouvertes.fr/hal-01084421
D. Schillinger, S. Hossain, and T. Hughes, Reduced Bézier element quadrature rules for quadratic and cubic splines in isogeometric analysis, Computer Methods in Applied Mechanics and Engineering, vol.277, pp.1-45, 2014.
J. Peters and U. Reif, Subdivision Surfaces, Springer Series in Geometry and Computing, 2008.
T. J. Cashman, Beyond Catmull-Clark? A survey of advances in subdivision surface methods, Computer Graphics Forum, vol.31, issue.1, pp.42-61, 2012.
T. Derose, M. Kass, and T. Truong, Subdivision Surfaces in Character Animation, Proceedings of the 25th Annual Conference on Computer Graphics and Interactive Techniques, SIGGRAPH '98, pp.85-94, 1998.
B. Thomaszewski, M. Wacker, and W. Straßer, A Consistent Bending Model for Cloth Simulation with Corotational Subdivision Finite Elements, Proceedings of the 2006 ACM SIG-GRAPH/Eurographics Symposium on Computer Animation, SCA '06, pp.107-116, 2006.
F. Cirak, M. Ortiz, and P. Schröder, Subdivision surfaces: a new paradigm for thin-shell finiteelement analysis, International Journal for Numerical Methods in Engineering, vol.47, issue.12, pp.2039-72, 2000.
F. Cirak and Q. Long, Subdivision shells with exact boundary control and non-manifold geometry, International Journal for Numerical Methods in Engineering, vol.88, issue.9, pp.897-923, 2011.
F. Cirak, M. Scott, E. Antonsson, M. Ortiz, and P. Schröder, Integrated modeling, finite-element analysis and engineering design for thin-shell structures using subdivision, Computer-Aided Design, vol.34, issue.2, pp.137-148, 2002.
F. Cirak and M. Ortiz, Fully C1-conforming subdivision elements for finite deformation thin-shell analysis, International Journal for Numerical Methods in Engineering, vol.51, issue.7, pp.813-833, 2001.
S. Green, G. Turkiyyah, and D. Storti, Subdivision-Based Multilevel Methods for Large Scale Engineering Simulation of Thin Shells, Proceedings of ACM Solid Modeling, 2002.
S. Green and G. Turkiyyah, Second Order Accurate Constraint Formulation for Subdivision Finite Element Simulation of Thin Shells, International Journal For Numerical Methods In Engineering, vol.61, issue.3, pp.380-405, 2004.
M. Antonelli, C. Beccari, G. Casciola, R. Ciarloni, and S. Morigi, Subdivision surfaces integrated in a CAD system, Computer-Aided Design, vol.45, pp.1294-1305, 2013.
I. Boier-martin and D. Zorin, Differentiable Parameterization of Catmull-Clark Subdivision Surfaces, Proceedings of the 2004 Eurographics/ACM SIGGRAPH Symposium on Geometry Processing, SGP '04, pp.155-164, 2004.
E. Catmull and J. Clark, Recursively generated B-spline surfaces on arbitrary topological meshes, Computer Aided Design, vol.10, pp.350-355, 1978.
D. Doo and M. Sabin, Behaviour of recursive division surfaces near extraordinary points, ComputerAided Design, vol.10, issue.6, pp.356-360, 1978.
C. Loop, Smooth spline surfaces over irregular meshes, SIGGRAPH '94: Proceedings of the 21st annual conference on Computer graphics and interactive techniques, pp.303-310, 1994.
U. Reif, A unified approach to subdivision algorithms near extraordinary vertices, Computer Aided Geometric Design, vol.12, pp.153-174, 1995.
U. Reif and P. Schröder, Curvature integrability of subdivision surfaces, Advances in Computational Mathematics, vol.14, issue.2, pp.157-174, 2001.
J. Peters and X. Wu, On the local linear independence of generalized subdivision functions, SIAM Journal on Numerical Analysis (SINUM), vol.44, issue.6, pp.2389-2407, 2006.
U. Zore, B. Jüttler, J. Kosinka, and ;. Nfn-g+s, On the Linear Independence of (Truncated) Hierarchical Subdivision Splines, 2014.
G. Arden, Approximation properties of subdivision surfaces, 2001.
J. Stam, Evaluation of Loop Subdivision Surfaces, Computer Graphics Proceedings, 1999.
E. Grinspun, P. Krysl, and P. Schröder, CHARMS: A Simple Franmework for Adaptive Simulation, 2002.
C. Bajaj and G. Xu, Anisotropic Diffusion of Subdivision Surfaces and Functions on Surfaces, ACM Transactions on Graphics, vol.22, issue.1, pp.4-32, 2003.
U. Clarenz, U. Diewald, and M. Rumpf, Processing textured surfaces via anisotropic geometric diffusion, IEEE Transactions on Image Processing, vol.13, issue.2, pp.248-261, 2004.
K. Hildebrandt and K. Polthier, Anisotropic Filtering of Non-Linear Surface Features, Eurographics, vol.23, issue.3
L. Dede and A. Quarteroni, Isogeometric Analysis for second order Partial Differential Equations on surfaces, Computer Methods in Applied Mechanics and Engineering, vol.284, pp.807-834, 2015.
U. Langer, A. Mantzaflaris, S. E. Moore, I. Toulopoulos, and ;. Nfn-g+s, Multipatch Discontinuous Galerkin Isogeometric Analysis, 2014.
U. Langer, S. E. Moore, and ;. Nfn-g+s, Discontinuous Galerkin Isogeometric Analysis of Elliptic PDEs on Surfaces, 2014.
P. J. Barendrecht, Isogeometric Analysis for Subdivision Surfaces, 2013.
A. Wawrzinek, K. Hildebrandt, and K. Polthier, Koiter's Thin Shells on Catmull-Clark Limit Surfaces, VMV 2011: Vision, Modeling & Visualization, pp.113-120, 2011.
E. Dikici, S. R. Snare, and F. Orderud, Isoparametric Finite Element Analysis for Doo-Sabin Subdivision Models, Proceedings of Graphics Interface, pp.19-26, 2012.
D. Burkhart, B. Hamann, and G. Umlauf, Iso-geometric analysis based on Catmull-Clark solid subdivision, Computer Graphics Forum, vol.29, issue.5, pp.1575-1784, 2010.
C. Loop, Smooth subdivision surfaces based on triangles, 1987.
E. Stollnitz, A. Derose, and D. Salesin, Wavelets for Computer Graphics: Theory and Applications, 1996.
S. C. Brenner and L. R. Scott, The mathematical theory of Finite Element methods, 2002.
D. Braess, Finite Elements, 2007.
P. G. Ciarlet, The finite element method for elliptic problems, no. 40 in Classics in applied mathematics, 2002.
G. Dziuk, Finite elements for the Beltrami operator on arbitrary surfaces, Partial Differential Equations and Calculus of Variations, vol.1357, pp.142-155, 1988.
R. Schaback, H. Werner, and N. Mathematik, , 1992.
D. A. Dunavant, High degree efficient symmetrical Gaussian quadrature rules for the triangle, Int. J. Numer. Meth. Engng, vol.21, pp.1129-1148, 1985.
L. Kobbelt, K. Daubert, and H. Seidel, Ray Tracing of Subdivision Surfaces, in: Rendering Techniques '98, Proceedings of the Eurographics Workshop in, pp.69-80, 1998.
G. Strang and G. J. Fix, An Analysis of the Finite Element Method, 1973.
J. K. Kowalski, Application of Box Splines to the Approximation of Sobolev Spaces, J. Approx. Theory, vol.61, pp.53-73, 1990.
