Characterization of bivariate hierarchical quartic box splines on a three-directional grid - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computer Aided Geometric Design Année : 2016
We consider the adaptive refinement of bivariate quartic C 2-smooth box spline spaces on the three-directional (type-I) grid G. The polynomial segments of these box splines belong to a certain subspace of the space of quar-tic polynomials, which will be called the space of special quartics. Given a bounded domain Ω ⊂ R 2 and finite sequence (G ℓ) ℓ=0,...,N of dyadically refined grids, we obtain a hierarchical grid by selecting mutually disjoint cells from all levels such that their union covers the entire domain. Using a suitable selection procedure allows to define a basis spanning the hierarchical box spline space. The paper derives a characterization of this space. Under certain mild assumptions on the hierarchical grid, the hierarchical spline space is shown to contain all C 2-smooth functions whose restrictions to the cells of the hierarchical grid are special quartic polynomials. Thus, in this case we can give an affirmative answer to the completeness questions for the hierarchical box spline basis.
hierarchical_box_splines.pdf (269.93 Ko) Télécharger le fichier
Format : Figure, Image
hal-02272184 , version 1 (27-08-2019)
Nelly Villamizar, Angelos Mantzaflaris, Bert Juettler. Characterization of bivariate hierarchical quartic box splines on a three-directional grid. Computer Aided Geometric Design, 2016, 41, pp.47-61. ⟨10.1016/j.cagd.2015.11.004⟩. ⟨hal-02272184⟩
23 Consultations
106 Téléchargements
