Isogeometric analysis using T-splines, Comp. Meth. Appl. Mech. Engrg, vol.199, issue.5-8, pp.229-263, 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-01517950
Analysis-suitable T-splines are dual-compatible, Comp. Meth. Appl. Mech. Engrg, issue.0, pp.42-51, 2012. ,
Some properties of LR-splines, Comp. Aided Geom. Design, vol.30, issue.8, pp.778-794, 2013. ,
A Hierarchical Construction of LR Meshes in 2D, NFN Geometry + Simulation, 2015. ,
Isogeometric mortar methods, Comp. Meth. Appl. Mech. Engrg, vol.284, pp.292-319, 2015. ,
Subdivision surfaces: a new paradigm for thinshell finite-element analysis, Int. J. Numer. Meth. in Engrg, vol.47, issue.12, pp.2039-2072, 2000. ,
Isogeometric analysis: toward integration of CAD and FEA, 2009. ,
Polynomial splines over locally refined boxpartitions, Comp. Aided Geom. Design, vol.30, issue.3, pp.331-356, 2013. ,
Adaptive isogeometric analysis by local hrefinement with T-splines, Comp. Meth. Appl. Mech. Engrg, vol.199, pp.264-175, 2010. ,
Hierarchical B-spline refinement, Proc. Siggraph, pp.205-212, 1988. ,
THB-splines: the truncated basis for hierarchical splines, Comp. Aided Geom. Design, vol.29, pp.485-498, 2012. ,
Strongly stable bases for adaptively refined multilevel spline spaces, Adv. Comput. Math, vol.40, issue.2, pp.459-490, 2014. ,
Nitsche's method for a coupling of isogeometric thin shells and blended shell structures, Comp. Meth. Appl. Mech. Engrg, vol.284, pp.881-905, 2015. ,
Isogeometric analysis using LR B-splines, Comp. Meth. Appl. Mech. Engrg, vol.269, pp.471-514, 2013. ,
Geometry + simulation modules: Implementing isogeometric analysis, vol.14, pp.961-962, 2014. ,
IETI -Isogeometric tearing and interconnecting, Comp. Meth. Appl. Mech. Engrg, pp.201-215, 2012. ,
Adaptive and linearly independent multilevel B-splines, Surface fitting and multiresolution methods, pp.209-218, 1997. ,
Multipatch discontinuous Galerkin isogeometric analysis, NFN Geometry + Simulation, 2014. ,
On linear independence of T-spline blending functions, Comp. Aided Geom. Design, vol.29, pp.63-76, 2012. ,
On the completeness of hierarchical tensorproduct B-splines, J. Comp. Appl. Math, vol.271, pp.53-70, 2014. ,
Isogeometric collocation: Cost comparison with Galerkin methods and extension to adaptive hierarchical NURBS discretizations, Comp. Meth. Appl. Mech. Engrg, vol.267, pp.170-232, 2013. ,
Isogeometric boundary element analysis using unstructured T-splines, Comp. Meth. Appl. Mech. Engrg, vol.254, pp.197-221, 2013. ,
Isogeometric spline forests, Comp. Meth. Appl. Mech. Engrg, vol.269, pp.222-264, 2014. ,
T-splines and t-nurccs, ACM Trans. Graph, vol.22, issue.3, pp.477-484, 2003. ,
A hierarchical approach to adaptive local refinement in isogeometric analysis, Comp. Meth. Appl. Mech. Engrg, vol.200, pp.3554-3567, 2011. ,
Adaptive isogeometric analysis using rational PHT-splines, Comp.-Aided Design, vol.43, pp.1438-1448, 2011. ,
Truncated hierarchical Catmull-Clark subdivision with local refinement, 2014. ,
Adaptively refined multilevel spline spaces from generating systems, Comp. Aided Geom. Design, pp.545-566, 2014. ,
On the linear independence of (truncated) hierarchical subdivision splines, NFN Geometry + Simulation, 2014. ,
