AllenRV: an Extensible Monitor for Multiple Complex Specifications with High Reactivity - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
AllenRV is a tool for monitoring temporal specifications, designed for ensuring good scalability in terms of size and number of formulae, and high reactivity. Its features reflect this design goal. For ensuring scalability in the number of formulae, it can simultaneously monitor a set of formulae written in past and future, next-free LTL, with some metric extensions; their efficient simultaneous monitoring is supported by a let construct allowing to share computations between formulae. For ensuring scalability in the size of formulae, it allows defining new abstractions as user-defined operators, which take discrete time boolean signals as arguments, but also constant parameters such as delays. For ensuring high reactivity, its monitoring algorithm does not require clock tick events, unlike many other tools. This is achieved by recomputing output signals both upon input signals changes and upon internally generated timeout events relative to such changes. As a consequence, monitoring remains efficient on arbitrarily fine-grained time domains. AllenRV is implemented by extending the existing Allen language and compiler, initially targeting ubiquitous applications using binary sensors, with temporal logic operators and a comprehensive library of user-defined operators on top of them. The most complex of these operators, including a complete adaptation of Allen-logic relations as selection operators, are proven correct with respect to their defined semantics. Thus, AllenRV offers an open platform for cooperatively developing increasingly complex libraries of high level, general or domain-specific, temporal operators and abstractions, without compromising correctness.
tool-final-20190722-fixed.pdf (239.64 Ko) Télécharger le fichier
hal-02272611 , version 1 (27-08-2019)
hal-02272611 , version 2 (28-08-2019)
  • HAL Id : hal-02272611 , version 2
Nic Volanschi, Bernard P. Serpette. AllenRV: an Extensible Monitor for Multiple Complex Specifications with High Reactivity. RV 2019 - The 19th International Conference on Runtime Verification, Oct 2019, Porto, Portugal. ⟨hal-02272611v2⟩
Collections
INRIA INRIA2
74 Consultations
155 Téléchargements
