A robust asymptotic observer for systems that converge to unobservable states. A batch reactor case study - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Automatic Control Année : 2020
In this paper we propose an observer for a dynam-ical system for which the states on the frontier of its domain are not observable, and all trajectories converge to the frontier. The proposed case study, a bioreactor in batch operating conditions with a single microbial reaction and gas production, is standard and largely encountered in practical situations. We show also how to extend this observer to obtain an observer in higher dimension that is robust with respect to unbiased noise.
obsbiogasrobustFINAL.pdf (1.18 Mo) Télécharger le fichier
hal-02272755 , version 1 (28-08-2019)
Alain Rapaport, Denis Dochain. A robust asymptotic observer for systems that converge to unobservable states. A batch reactor case study. IEEE Transactions on Automatic Control, 2020, 65 (6), pp.2693-2699. ⟨10.1109/TAC.2019.2940870⟩. ⟨hal-02272755⟩
251 Consultations
225 Téléchargements
