New interface
Conference papers
Cost-driven framework for progressive compression of textured meshes
Abstract : Recent advances in digitization of geometry and radiometry generate in routine massive amounts of surface meshes with texture or color attributes. This large amount of data can be compressed using a progressive approach which provides at decoding low complexity levels of details (LoDs) that are continuously refined until retrieving the original model. The goal of such a progressive mesh compression algorithm is to improve the overall quality of the transmission for the user, by optimizing the rate-distortion trade-off. In this paper, we introduce a novel meaningful measure for the cost of a progressive transmission of a textured mesh by observing that the rate-distortion curve is in fact a staircase, which enables an effective comparison and optimization of progressive transmissions in the first place. We contribute a novel generic framework which utilizes the cost function to encode triangle surface meshes via multiplexing several geometry reduction steps (mesh decimation via half-edge or full-edge collapse operators, xyz quantization reduction and uv quantization reduction). This framework can also deal with textures by multiplexing an additional texture reduction step. We also design a texture atlas that enables us to preserve texture seams during decimation while not impairing the quality of resulting LODs. For encoding the inverse mesh decimation steps we further contribute a significant improvement over the state-of-the-art in terms of rate-distortion performance and yields a compression-rate of 22:1, on average. Finally, we propose a unique single-rate alternative solution using a selection scheme of a subset among LODs, optimized for our cost function, and provided with our atlas that enables interleaved progressive texture refinements.
Document type :
Conference papers
Complete list of metadata
Cited literature [25 references]  Display  Hide  Download
https://hal.inria.fr/hal-02273929
Contributor : Pierre Alliez Connect in order to contact the contributor
Submitted on : Friday, October 18, 2019 - 2:28:19 PM
Last modification on : Saturday, November 19, 2022 - 3:58:47 AM
Long-term archiving on: : Sunday, January 19, 2020 - 3:11:21 PM
Cost-Driven_Framework_for_Prog...
Identifiers
Citation
Cédric Portaneri, Pierre Alliez, Michael Hemmer, Lukas Birklein, Elmar Schoemer. Cost-driven framework for progressive compression of textured meshes. ACM 2019 - 10th Multimedia Systems Conference, Jun 2019, Amherst, United States. pp.175-188, ⟨10.1145/3304109.3306225⟩. ⟨hal-02273929⟩
Share
Metrics
Record views
191
Files downloads
138
