Transportation Management and Decision Support Systems within the Supply Chain Management Framework - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
With technology and globalization, supply chain expanded and therefore supporting software is required in order to ensure prompt decisions are appropriately made. The emphasis of this paper is on the transportation management system (TPS) that supports the decision making process within the supply chain management framework. Our hypothesis focuses on the routing and mapping module within TPS. To support the hypothesis, questionnaires were distributed to the managers of small scale businesses in Al-Shuwaikh commercial district in Kuwait and the results obtained helped rank the importance of four carefully selected modules embraced by transportation management systems. A methodical regression analysis approach was used to substantiate the findings as elucidated in the study presented here.
474698_1_En_30_Chapter.pdf (307.32 Ko) Télécharger le fichier
hal-02274167 , version 1 (29-08-2019)
Paternité
Issam Moghrabi, Fatemah O. Ebrahim. Transportation Management and Decision Support Systems within the Supply Chain Management Framework. 17th Conference on e-Business, e-Services and e-Society (I3E), Oct 2018, Kuwait City, Kuwait. pp.337-343, ⟨10.1007/978-3-030-02131-3_30⟩. ⟨hal-02274167⟩
67 Consultations
113 Téléchargements
