A New Aggregation Rule for Ranking Suppliers in Group Decision Making under Multiple Criteria, Journal of Supply Chain Management Systems, vol.4, pp.38-49, 2016. ,
, Transp. in Dev. Econ, vol.4, 2018.
An unpopular essay on transportation, Journal of Transport Geography, vol.9, pp.1-11, 2001. ,
Integrating transport systems in supply chain management software tools, Industrial Management & Data Systems, vol.103, issue.7, pp.503-515, 2003. ,
Transportation Management System Functions and Performance Amplifying the Span of Small Scale Firms, Journal of Supply Chain Management Systems, issue.4, 2016. ,
A fuzzy approach to transport optimization problem, Optim Eng, vol.17, p.981, 2016. ,
Electronic commerce" in A manager's guide, pp.285-316, 1997. ,
A Decision Support System for Warehouse Location Selection: A Case Study, Journal of Supply Chain Management Systems, issue.4, 2016. ,
Optimization of supply chain network modeling and performance measurement in flow of production, Journal of Supply Chain Management Systems, vol.3, issue.4, pp.1-6, 2014. ,
A spectrum of compromise aggregation operators for multiple attribute decision making, Artificial Intelligence, vol.171, pp.161-184, 2007. ,
The transport selection criteria of Norwegian Exporters, International Journal of Physical Distribution & Logistics Management, vol.28, issue.2, 1998. ,
Evaluation of the strategies of target market selection on the basis of IFE and EFE matrixes using LINMAP technique, Iranian Journal of Management Studies (IJMS), vol.3, issue.3, pp.41-58, 2010. ,
Multi criteria decision making methods: A comparative study, 2000. ,
A preference aggregation method through the estimation of utility intervals, Computers & Operations Research, vol.32, pp.2027-2049, 2005. ,
An analysis of AHP comparisons and priorities, pp.16-28, 2008. ,
Multi attribute decision making: A simulation comparisons of select methods, European Journal of Operational Research, vol.107, issue.3, pp.507-529, 1998. ,
A new spanning tree-based genetic algorithm for the design of multistage supply chain networks with nonlinear transportation costs, Optim Eng, vol.10, p.219, 2009. ,
