, for i in range(16): dico_DDT
, dico_DDT
, Utranspose"+str(i)) (mat): return [[ abs(mat[i][j]) for j in range (mat.ncols())] for i in range, dico_DDT
, range(16)): signature=(i,k1,k0) #used to identify the component we are looking at latint=spectrum_to_int, dico_DDT_and_LAT=defaultdict(list) for i,k1,k0 in itertools.product(range(16),range(16)
, (i,k1,k0)!=(j,k1j,k0j)): if(len(affine_equivalence, Affine Equivalence for key in dico_DDT_and_LAT: for (i,k1,k0) in dico_DDT_and_LAT[key]: for (j,k1j,k0j) in dico_DDT_and_LAT
, Chi-squared Distribution Table (d.f. means "degree of freedom"), vol.5
Dual-mode Cellular System: Authentication, Message Encryption, Voice Privacy Mask Generation, Shared Secret Data Generation, A-Key Verification, and Test Data, 1992. ,
Sok: Peigen -a platform for evaluation, implementation, and generation of s-boxes, 2019. ,
Differential cryptanalysis of DES-like cryptosystems, Advances in Cryptology-CRYPTO' 90, vol.537, pp.2-21, 1991. ,
, The Sage Developers. SageMath, the Sage Mathematics Software System, 2017.
AES submission document on Rijndael, 1998. ,
Probability distributions of correlation and differentials in block ciphers, Journal of Mathematical Cryptology, vol.1, issue.3, pp.221-242, 2007. ,
Cryptosystem for cellular telephony, vol.5, 1991. ,
Optimizing implementations of lightweight building blocks, IACR Transactions on Symmetric Cryptology, vol.2017, issue.4, pp.130-168, 2017. ,
A new method for known plaintext attack of feal cipher, Advances in Cryptology -EUROCRYPT' 92, vol.1440, pp.81-91, 1993. ,
Reverse-Engineering and Design of Symmetric Cryptographic Algorithms, 2017. ,
SboxU (S-box utils), 2019. ,
Published by the 3rd Generation Partnership Project 2 "3GPP2, 2009. ,
A known plaintext attack of feal-4 and feal-6, Advances in Cryptology -CRYPTO '91, vol.576, pp.172-182, 1992. ,
Cryptanalysis of the cellular message encryption algorithm, Advances in Cryptology -CRYPTO '97, vol.1294, pp.526-537, 1997. ,
