Data-Locality Aware Dynamic Schedulers for Independent Tasks with Replicated Inputs, IPDPSW 2018 IEEE International Parallel and Distributed Processing Symposium Workshops, pp.1-8, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01878977
An Analysis of Traces from a Production MapReduce Cluster, International Conference on Cluster, Cloud and Grid Computing (CCGrid), pp.94-103, 2010. ,
Computers and Intractability, a Guide to the Theory of NP-Completeness, 1979. ,
, , p.39, 2008.
Delay Scheduling: A Simple Technique for Achieving Locality and Fairness in Cluster Scheduling, European Conference on Computer Systems (EuroSys), pp.265-278, 2010. ,
Degree-Guided Map-Reduce Task Assignment with Data Locality Constraint, International Symposium on Information Theory (ISIT), pp.985-989, 2012. ,
Quincy: Fair Scheduling for Distributed Computing Clusters, Symposium on Operating Systems Principles (SOSP, pp.261-276, 2009. ,
Maestro: Replica-Aware Map Scheduling for MapReduce, International Symposium on Cluster, Cloud and Grid Computing (CCGrid), pp.435-442, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00670813
, Map Task Scheduling in MapReduce with Data Locality: Throughput and HeavyTraffic Optimality, pp.1609-1617, 2013.
Investigation of Data Locality in MapReduce, International Symposium on Cluster, Cloud and Grid Computing (CCGrid), pp.419-426, 2012. ,
, Flows in Networks, 2015.
, Firmament: Fast, Centralized Cluster Scheduling at Scale, in: Symposium on Operating Systems Design and Implementation (OSDI), USENIX, pp.99-115, 2016.
Locality-aware and load-balanced static task scheduling for mapreduce, Future Generation Computer Systems, vol.90, pp.49-61, 2019. ,
, Randomization and Approximation Techniques in Computer Science (RANDOM), pp.159-170, 1998.
On weighted Balls-into-Bins Games, Theoretical Computer Science (TCS), vol.409, issue.3, pp.511-520, 2008. ,
The Power of Two Choices in Randomized Load Balancing, Transactions on Parallel and Distributed Systems (TPDS), vol.12, issue.10, pp.1094-1104, 2001. ,
The Power of Two Random Choices: A Survey of Techniques and Results, Combinatorial Optimization, vol.9, pp.255-304, 2001. ,
Balanced Allocations: The Heavily Loaded Case, Symposium on Theory of Computing (STOC), pp.745-754, 2000. ,
The (1+ ?)-Choice Process and Weighted Balls-into-Bins, Symposium on Discrete Algorithms (SODA), SIAM, pp.1613-1619, 2010. ,
Scheduling tasks sharing files from distributed repositories, Proceedings of the 10th International Euro-Par Conference, pp.246-253, 2004. ,
URL : https://hal.archives-ouvertes.fr/hal-00807284
Heuristics for scheduling file-sharing tasks on heterogeneous systems with distributed repositories, J. Parallel Distrib. Comput, vol.67, issue.3, pp.271-285, 2007. ,
URL : https://hal.archives-ouvertes.fr/hal-00803511
Heuristics for scheduling parameter sweep applications in grid environments, 9th Heterogeneous Computing Workshop, pp.349-363, 2000. ,
URL : https://hal.archives-ouvertes.fr/hal-00748942
, Probability and Computing -Randomized Algorithms and Probabilistic Analysis, 2005.
Semi-matchings for bipartite graphs and load balancing, Journal of Algorithms, vol.59, issue.1, pp.53-78, 2006. ,
Minimizing average flow time with parallel machines, Operations Research, vol.21, issue.3, pp.846-847, 1973. ,
Scheduling independent tasks to reduce mean finishing time, Communications of the ACM, vol.17, issue.7, pp.382-387, 1974. ,
Algorithmics of two-sided matching problems, 2003. ,
Faster algorithms for semi-matching problems, ACM Transactions on Algorithms (TALG), vol.10, issue.3, p.14, 2014. ,
On computing an optimal semi-matching, International Workshop on Graph-Theoretic Concepts in Computer Science, pp.250-261, 2011. ,
Fast Concurrent Access to Parallel Disks, Algorithmica, vol.35, issue.1, pp.21-55, 2003. ,
Perfectly Balanced Allocation, Approximation, Randomization, and Combinatorial Optimization (APPROX, pp.240-251, 2003. ,
On the Effect of Replication of Input Files on the Efficiency and the Robustness of a Set of Computations, 2017. ,
URL : https://hal.archives-ouvertes.fr/tel-01661588
