Pithextract: A robust algorithm for pith detection in computer tomography images of wood-application to 125 logs from 17 tree species, vol.85, pp.90-98, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-01003417
Blue intensity in pinus sylvestris tree-rings: developing a new palaeoclimate proxy, The Holocene, vol.17, issue.6, pp.821-828, 2007. ,
Towards an automated generation of tree ring profiles from ctimages, Image and Signal Processing and Analysis (ISPA). 5th International Symposium on, pp.174-179, 2007. ,
Towards automatic tree rings detection in images of scanned wood samples, Computers and Electronics in Agriculture, vol.140, pp.279-289, 2017. ,
Determining the average annual ring width on the front side of lumber, Optical Measurement Systems for Industrial Inspection III, vol.5144, pp.707-717, 2003. ,
A fast algorithm to approximate the pith location of rubberwood timber from a normal camera image, 15th International Joint Conference on Computer Science and Software Engineering (JCSSE), pp.1-6, 2018. ,
Automatic detection of pith on ct images of spruce logs, Computers and Electronics in Agriculture, vol.44, issue.2, pp.107-119, 2004. ,
Estimation of pith position in untreated log ends in sawmill environments, Computers and Electronics in Agriculture, vol.63, issue.2, pp.155-167, 2008. ,
Pith estimation on rough log end images using local fourier spectrum analysis, Proceedings of the 14th Conference on Computer Graphics and Imaging (CGIM'13), 2013. ,
On the use of x-ray computed tomography for determining wood properties: a review, Canadian journal of forest research, vol.41, issue.11, pp.2120-2140, 2011. ,
Automatic measurement of sister chromatid ex-change frequency, Journal of Histochemistry & Cytochemistry, vol.25, issue.7, pp.741-753, 1977. ,
