Isogeometric analysis of high order partial differential equations on surfaces, Comput. Methods Appl. Mech. Engrg, vol.295, pp.446-469, 2015. ,
An isogeometric method for the Reissner-Mindlin plate bending problem, Comput. Methods Appl. Mech. Engrg, vol.209, pp.45-53, 2012. ,
Smooth Bézier Surfaces over Unstructured Quadrilateral Meshes. Lecture Notes of the Unione Matematica Italiana, 2017. ,
Bases and dimensions of C 1 -smooth isogeometric splines on volumetric two-patch domains, Graph. Mod, vol.99, pp.46-56, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-02271820
The space of C 1 -smooth isogeometric spline functions on trilinearly parameterized volumetric two-patch domains, Comput. Aided Geom. Des, vol.70, pp.16-30, 2019. ,
Analysis-suitable G 1 multi-patch parametrizations for C 1 isogeometric spaces, Comput. Aided Geom. Des, vol.47, pp.93-113, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01404076
Isogeometric Analysis: Toward Integration of CAD and FEA, 2009. ,
Isogeometric analysis for topology optimization with a phase field model, Arch. Comput. Methods Engrg, vol.19, pp.427-465, 2012. ,
Matched G k -constructions always yield C k -continuous isogeometric elements, Comput. Aided Geom. Des, vol.34, pp.67-72, 2015. ,
Isogeometric analysis with geometrically continuous functions on planar multi-patch geometries, Comput. Methods Appl. Mech. Engrg, vol.316, pp.209-234, 2017. ,
Construction of analysis-suitable G 1 planar multi-patch parameterizations, Comput. Aided Des, vol.97, pp.41-55, 2018. ,
Space of C 2 -smooth geometrically continuous isogeometric functions on planar multi-patch geometries: Dimension and numerical experiments, Comput. Math. Appl, vol.73, issue.10, pp.2319-2338, 2017. ,
Isogeometric analysis with geometrically continuous functions on two-patch geometries, Comput. Math. Appl, vol.70, issue.7, pp.1518-1538, 2015. ,
Dimension and bases for geometrically continuous splines on surfaces of arbitrary topology, Comput. Aided Geom. Des, vol.45, pp.108-133, 2016. ,
C 1 finite elements on non-tensor-product 2d and 3d manifolds, Appl. Math. and Comp, vol.272, pp.148-158, 2016. ,
Geometric continuity, Handbook of computer aided geometric design, pp.193-227, 2002. ,
