The conditioning of boundary element equations on 981 locally refined meshes and preconditioning by diagonal scaling, SIAM J. Numer. Anal, vol.982, pp.1901-1932, 1999. ,
An optimal domain decomposition preconditioner for low-frequency 984 time harmonic Maxwell equations, Math. Comp, vol.68, pp.607-631, 1999. ,
Vector potentials in three-dimensional 986 non-smooth domains, Math. Meth. Appl. Sci, vol.21, pp.823-864, 1998. ,
Mathematical foundations of computational elec-988 tromagnetism, Applied Mathematical Sciences, vol.198, 2018. ,
Uncertainty quantification for Maxwell's equations using stochastic 990 collocation and model order reduction, International Journal for Uncertainty Quantifica-991 tion, vol.5, pp.195-208, 2015. ,
Regularity of the Maxwell equations in heteroge-993 neous media and Lipschitz domains, J. Math. Anal. Appl, vol.408, pp.498-512, 2013. ,
T-coercivity for the Maxwell problem 995 with sign-changing coefficients, Communications in PDEs, vol.39, pp.1007-1031, 2014. ,
Two-dimensional Maxwell's equations 997 with sign-changing coefficients, Appl. Numer. Math, vol.79, pp.29-41, 2014. ,
The mathematical theory of finite element methods ,
Constructive formulations of resonant Maxwell's equations ,
, SIAM J. Math. Anal, vol.49, pp.3637-3670, 2017.
Interpolation of Hilbert and Sobolev spaces: 1003 quantitative estimates and counterexamples, Mathematika, vol.61, pp.414-443, 2015. ,
On the approximation of electromagnetic fields by edge finite elements, vol.1, p.1005 ,
URL : https://hal.archives-ouvertes.fr/hal-02276430
, Sharp interpolation results for low-regularity fields, Comput. Math. Appl, vol.71, p.1006, 2016.
On the approximation of electromagnetic fields by 1007 edge finite elements. Part 2: A heterogeneous multiscale method for Maxwell's equations ,
, Comput. Math. Appl, vol.73, 1900.
Singularities of Maxwell interface problems. Math. 1010 Mod, Num. Anal, vol.33, pp.627-649, 1999. ,
Singularities of eddy current problems, Math. Mod. 1012 Num. Anal, vol.37, pp.807-831, 2003. ,
Benchmark computations for Maxwell equations ,
Neumann and mixed problems on curvilinear polyhedra, Integr. Equat. Oper. Th, vol.15, pp.227-261, 1016. ,
Hybrid resonance of Maxwell's equations in 1018 slab geometry, J. Math. Pures Appl, vol.101, pp.623-659, 2014. ,
Finite element quasi-interpolation and best approximation, vol.51, pp.1367-1385, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01155412
Analysis of the edge finite element approximation of the Maxwell 1022 equations with low regularity solutions, Comput. Math. Appl, vol.75, p.1024, 1985. ,
Singularities in boundary value problems, RMA. Masson, vol.22, p.1025, 1992. ,
, Electromagnetic theory and computation: a topological approach. 1026 MSRI Publications Series, vol.48, 2004.
Additive Schwarz method for the p-version of the boundary element method for the 1028 single layer potential operator on a plane screen, Numer. Math, vol.88, p.1029, 2001. ,
On the equivalence of fractional-order Sobolev semi-norms, J. Math. Anal. Appl, vol.417, pp.505-518, 1030. ,
The inhomogeneous Dirichlet problem in Lipschitz domains, J. 1032 Functional Analysis, vol.130, pp.161-219, 1995. ,
An H s -regularity result for the gradient of solutions to elliptic equations with 1034 mixed boundary conditions, J. Math. Anal. Appl, vol.238, pp.429-450, 1999. ,
Problèmes aux limites non homogènes et applications. Dunod, 10361968. ,
Finite element methods for Maxwell's equations, p.1038, 2003. ,
Mixed finite elements in R 3, J.-C. Nédélec. Acoustic and Electromagnetic Equations, vol.35, p.1040, 2001. ,
Regularity results for elliptic equations in Lipschitz domains, J. Funct. Anal, vol.152, pp.176-201, 1041. ,
An introduction to Sobolev spaces and interpolation spaces, vol.3, 2007. ,
, The MORwiki Community. Coplanar waveguide. MORwiki -Model Order Reduction Wiki, 1045.
Quantification de l'incertain enélectromagnétisme : identification des 1047 dépendances par rapport aux paramètres, p.1048 ,
, , 2016.
, For all s, s ? (0, 1), s ? s : 1062 ?C (s,s ) , ?v ? H s , v Hs ? C (s,s ) v H s
, H s ? H 0 : 1064 ?c 0 > 0, ?s ? (0, 1), ?v ? H s , v H0 ? c 0 s 1/2 (1 ? s) 1/2 v Hs
, H 1 ? H s : 1066 ?c 1 > 0, ?s ? (0, 1), ?v ? H 1 , s 1/2 (1 ? s) 1/2 v Hs ? c 1 v H1
