Combining Size-Based Load Balancing with Round-Robin for Scalable Low Latency - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Parallel and Distributed Systems Année : 2019
SITA_RR.pdf (473.58 Ko) Télécharger le fichier
hal-02276789 , version 1 (10-10-2019)
hal-02276789 , version 2 (17-10-2019)
Jonatha Anselmi. Combining Size-Based Load Balancing with Round-Robin for Scalable Low Latency. IEEE Transactions on Parallel and Distributed Systems, 2019, 31 (4), pp. 886-896. ⟨10.1109/TPDS.2019.2950621⟩. ⟨hal-02276789v2⟩
142 Consultations
407 Téléchargements
