Abstract : With the data volume increasing, key-value (KV) store plays an important role in today’s storage systems due to its flexible architecture and good scalability. There are two types of data organization in current KV stores: key-order layout and write-order layout, which organize records according to key order and write sequence, respectively. While the former and the latter layouts deliver high throughput for range-query and write operations respectively, neither of them can perform well for both write and range-query operations. In this paper, we propose a hybrid KV store, KT-Store, which combines the key-order and write-order layout together to improve performance. More specifically, KT-Store stores keys and value metadata into a LSM-tree, and stores values into multiple tables called TrieTables. By inserting the value among multiple TrieTables in a key-order fashion leveraging a trie, and into a specific TrieTable in a write-order fashion, KT-Store can obtain the advantages of existing two layout types and avoid their shortcomings. We implement KT-Store in RocksDB 5.7.2. Extensive evaluations demonstrate that KT-Store can simultaneously obtain encouraging write and range-query performance: compared with key-order based RocksDB, the write performance is improved by $$4.3\times -12.6\times $$ on HDDs; compared with write-order based Wisckey, KT-Store has $$54.2\times -112.6\times $$ range-query performance on HDDs. Besides, KT-Store also has encouraging performance on SSDs.
https://hal.inria.fr/hal-02279544 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Thursday, September 5, 2019 - 1:30:45 PM Last modification on : Thursday, September 5, 2019 - 1:35:36 PM Long-term archiving on: : Thursday, February 6, 2020 - 2:28:40 AM
Haobo Wang, Yinliang Yue, Shuibing He, Weiping Wang. KT-Store: A Key-Order and Write-Order Hybrid Key-Value Store with High Write and Range-Query Performance. 15th IFIP International Conference on Network and Parallel Computing (NPC), Nov 2018, Muroran, Japan. pp.64-76, ⟨10.1007/978-3-030-05677-3_6⟩. ⟨hal-02279544⟩
