Conference papers
Balancing the QOS and Security in Dijkstra Algorithm by SDN Technology
Abstract : Dijkstra algorithm is widely used in a lot of common network routing protocols. We consider the problem of quality of service (QoS) and the Security features of the network routing area using software defined networks (SDN). The SDN framework enables an efficient decoupled implementation of dynamic routing protocols which could aware the communication network status. In this work we consider the varying delay status of the communication network along with other network security parameters. The routing problem is formulated as a multi-constrained shortest path problem. A new improved Dijkstra algorithm is presented named as QS-Dijkstra. The implement and experiment show that QS-Dijkstra algorithm is able to minimize traffic routing through vulnerable links while satisfying the QoS constraints of the network.
Document type :
Conference papers
Complete list of metadata
Cited literature [5 references]  Display  Hide  Download
https://hal.inria.fr/hal-02279549
Contributor : Hal Ifip Connect in order to contact the contributor
Submitted on : Thursday, September 5, 2019 - 1:31:00 PM
Last modification on : Thursday, November 12, 2020 - 9:12:01 PM
Long-term archiving on: : Thursday, February 6, 2020 - 8:42:34 AM
File
477597_1_En_11_Chapter.pdf
Identifiers
Citation
Jinjing Zhao, Ling Pang, Xiaohui Kuang, Rong Jin. Balancing the QOS and Security in Dijkstra Algorithm by SDN Technology. 15th IFIP International Conference on Network and Parallel Computing (NPC), Nov 2018, Muroran, Japan. pp.126-131, ⟨10.1007/978-3-030-05677-3_11⟩. ⟨hal-02279549⟩
Share
Metrics
Record views
106
Files downloads
78
