, Search of an Understandable Consensus Algorithm. USENIX Annul Technical Conference, 2013.
Disk failures in the real world: What does an mttf of 1, 000, 000 hours mean to you? FAST, vol.7, pp.1-16, 2007. ,
, Non-volatile memory, 2018.
, Paxos Made Simple. ACM SIGACT News (Distributed Computing Column), vol.32, 2001.
, , 2018.
, , 2018.
, , 2018.
, Spanner: Googles Globally-Distributed Database, vol.31, p.8, 2012.
, , 2018.
Benchmarking cloud serving systemswith ycsb, ACM Symposium on Cloud Computing, p.12, 2010. ,
, , 2018.
, , 2018.
APUS: Fast and Scalable Paxos on RDMA, Proceedings of SoCC 17, vol.14, p.16, 2017. ,
Incremental Consistency Guarantees for Replicated Objects, the Proceedings of the 12th USENIX Symposium on Operating Systems Design and Implementation ,
, A distributed in-memory key-value store system on heterogeneous CPU-GPU cluster, vol.26, p.729750, 2017.
, Scalable Transactions across Heterogeneous NoSQL Key-Value Data Stores. The 39th International Conference on Very Large Data Bases, 2013.
, Strata: A Cross Media File System. ACM Symposium on Operating Systems Principles, 2017.
, OctopusFS: A Distributed File System with Tiered Storage Management. ACM Conference on Management of Data, 2017.
