On Retargeting the AI Programming Framework to New Hardwares - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Nowadays, a large number of accelerators are proposed to increase the performance of AI applications, making it a big challenge to enhance existing AI programming frameworks to support these new accelerators. In this paper, we select TensorFlow to demonstrate how to port the AI programming framework to new hardwares, i.e., FPGA and Sunway TaihuLight here. FPGA and Sunway TaihuLight represent two distinct and significant hardware architectures for considering the retargeting process. We introduce our retargeting processes and experiences for these two platforms, from the source codes to the compilation processes. We compare the two retargeting approaches and demonstrate some preliminary experimental results.
477597_1_En_4_Chapter.pdf (336.25 Ko) Télécharger le fichier
hal-02279561 , version 1 (05-09-2019)
Paternité
Jiacheng Zhao, Yisong Chang, Denghui Li, Chunwei Xia, Huimin Cui, et al.. On Retargeting the AI Programming Framework to New Hardwares. 15th IFIP International Conference on Network and Parallel Computing (NPC), Nov 2018, Muroran, Japan. pp.39-51, ⟨10.1007/978-3-030-05677-3_4⟩. ⟨hal-02279561⟩
55 Consultations
121 Téléchargements
