New interface
Conference papers
A Creative Design Approach Based on TRIZ and Knowledge Fusion
Abstract : Knowledge is an important driving force for creative design. The knowledge fusion, which is formulated by knowledge from different backgrounds, is able to inspire novelty solutions to engineering design. In this paper, a design method is proposed to facilitate knowledge fusion in engineering design based on the theory of inventive problem solving (TRIZ). In order to formulate this method, the mechanism that fosters creative ideas through knowledge fusion is firstly explained, subsequently, approaches that transform the design problems in each of the above-mentioned design stages into TRIZ problems are discussed, since the standard problems in TRIZ can be solved by corresponding TRIZ methods. A design process is therefore formulated by integrating formerly discussed strategies. Moreover, its workability is verified by a case study. The advantages of the proposed method such as the expanding the searchable range of knowledge resource for TRIZ problem solving are discussed in the final section.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/hal-02279771
Contributor : Hal Ifip Connect in order to contact the contributor
Submitted on : Thursday, September 5, 2019 - 3:16:59 PM
Last modification on : Thursday, September 5, 2019 - 3:56:18 PM
Long-term archiving on: : Thursday, February 6, 2020 - 2:01:54 AM
File
474537_1_En_14_Chapter.pdf
Identifiers
Citation
Wei Liu, Run-Hua Tan, Ya-Fan Dong, Guozhong Cao, Limeng Liu. A Creative Design Approach Based on TRIZ and Knowledge Fusion. 18th TRIZ Future Conference (TFC), Oct 2018, Strasbourg, France. pp.167-179, ⟨10.1007/978-3-030-02456-7_14⟩. ⟨hal-02279771⟩
Share
Metrics
Record views
21
Files downloads
47
