X: Evacuation Planning for Disaster Responses: A Stochastic Programming Framework, Transportation Research Part C, vol.69, pp.150-172, 2016. ,
A transportation network evacuation model, Transp. Res. Part A: Policy Pract, vol.16, issue.3, pp.209-218, 1982. ,
A network approach to a city emergency evacuation planning, Int. J. Syst. Sci, vol.27, issue.10, pp.931-936, 1996. ,
Mathematical modeling of evacuation problems: a state of art, Berichte des Frauenhofer ITWM, issue.24, 2001. ,
A network flow model for lane-based evacuation routing, Transp. Res. Part A: Policy Pract, vol.37, issue.7, pp.579-604, 2003. ,
Lane-based evacuation network optimization: an integrated lagrangian relaxation and tabu search approach, Transp. Res. Part C: Emerg. Technol, vol.19, issue.1, pp.40-63, 2011. ,
S: Evacuation planning: a capacity constrained routing approach, Intelligence and Security Informatics, pp.111-125, 2003. ,
Optimal scheduling of evacuation operations, Transp. Res. Rec.: J. Transp. Res. Board, vol.1964, issue.1, pp.238-246, 2006. ,
Global optimization of emergency assignments, Interfaces, vol.36, issue.6, pp.502-513, 2006. ,
Impact of probabilistic road capacity constraints on the spatial distribution of hurricane evacuation shelter capacities, Transp. Res. Rec.: J. Transp. Res. Board, vol.2022, pp.55-62 ,
Evacuation network modeling via dynamic traffic assignment with probabilistic demand and capacity constraints, Transp. Res. Rec.: J. Transp. Res. Board, vol.46, pp.11-20, 2010. ,
Maximal dynamic expected flows problem for emergency evacuation planning, Transp. Res. Rec.: J. Transp. Res. Board, vol.44, pp.26-34, 2008. ,
Evacuation planning with endogenous transportation network degradations: a stochastic cell-based model and solution procedure, Networks Spatial Econ, pp.1-20, 2014. ,
