Decolonising Neo-Liberal Innovation: Using the Andean Philosophy of ‘Buen Vivir’ to Reimagine Innovation Hubs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Andrea Jimenez
  • Fonction : Auteur
  • PersonId : 1053549
Tony Roberts
  • Fonction : Auteur
  • PersonId : 1023889
Innovation is increasingly portrayed as central to social and economic development. Models of innovation from the global North are often applied uncritically in the global South. Doing so may unwittingly silence indigenous knowledge, ways of knowing, and cultural values. Santos (2014) has argued that this form of epistemic violence is committed when actors from the global North are insufficiently mindful of ‘Epistemologies of the South’. Neither Santos nor the authors of this paper believe that there is nothing of value to be learned from the global North – only that there is as much to be learned from the global South – and everything to be gained from a skillful combination of different ways of knowing. This theoretical paper proposes a future line of research to examine in what ways Epistemologies of the South might inform innovation processes to produce different outcomes. We use the example of innovation hubs and although we might have used the philosophies of Ubuntu from Southern Africa or Swaraj from India, in this paper we use the lens of Buen Vivir (living well) from Andean and Amazonian communities in South America to suggest that another innovation is possible.
484106_1_En_15_Chapter.pdf (125.39 Ko) Télécharger le fichier
hal-02281295 , version 1 (09-09-2019)
Paternité
Andrea Jimenez, Tony Roberts. Decolonising Neo-Liberal Innovation: Using the Andean Philosophy of ‘Buen Vivir’ to Reimagine Innovation Hubs. 15th International Conference on Social Implications of Computers in Developing Countries (ICT4D), May 2019, Dar es Salaam, Tanzania. pp.180-191, ⟨10.1007/978-3-030-19115-3_15⟩. ⟨hal-02281295⟩
131 Consultations
318 Téléchargements
