Unpacking Empowerment in ICT4D Research - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Priyanka Pandey
  • Fonction : Auteur
  • PersonId : 1053567
Yingqin Zheng
  • Fonction : Auteur
  • PersonId : 983563
Information and communication technology is said to provide paths to empowerment, yet the current ICT4D literature weakly conceptualises how this occurs. This article questions the conceptual alignment between the empowerment concept and the actual empowerment outcome attained through technology. We use Alsop and Heinsohn’s measuring empowerment framework and Zimmerman’s individual empowerment framework to analyse the missing links between empowerment and technology within current ICT4D research. We argue that research on empowerment in ICT4D needs to (1) be more specific about what type of empowerment takes place; (2) take into account both agency level changes and socio-institutional structures, (3) consider the dual effect of both empowerment and disempowerment.
484106_1_En_8_Chapter.pdf (97.76 Ko) Télécharger le fichier
hal-02281310 , version 1 (09-09-2019)
Paternité
Priyanka Pandey, Yingqin Zheng. Unpacking Empowerment in ICT4D Research. 15th International Conference on Social Implications of Computers in Developing Countries (ICT4D), May 2019, Dar es Salaam, Tanzania. pp.83-94, ⟨10.1007/978-3-030-19115-3_8⟩. ⟨hal-02281310⟩
57 Consultations
147 Téléchargements
