Feedback Control with Equilibrium Revision for CMG-Actuated Inverted Pendulum - Archive ouverte HAL Access content directly
Book Sections Year : 2020
(1) , (1) , (1) , (1) , (1) , (1) , (2) , (3)
1
2
3
The chapter centers around the problem of design a feedback control for the control moment gyroscope (CMG)-actuated inverted pendulum with online equilibrium revision after the center of mass displacement. The methodology for the control synthesis is the linear–quadratic regulator. The equations of motion for the model of the inverted pendulum are derived. The control is synthesized and implemented both in an experimental plant and in a simulation model. The results of the experiment and simulation show the reliability of the synthesized control, which is proved to be able to deal with the center of mass displacement.
zavalishin_readings.pdf (195.8 Ko) Télécharger le fichier
Dates and versions
hal-02282908 , version 1 (10-09-2019)
Identifiers
Cite
Igor Ryadchikov, Semyon Sechenev, Nikita Mikhalkov, Andrey Biryuk, Alexander Svidlov, et al.. Feedback Control with Equilibrium Revision for CMG-Actuated Inverted Pendulum. Proceedings of 14th International Conference on Electromechanics and Robotics "Zavalishin's Readings", pp.431-440, 2020, ⟨10.1007/978-981-13-9267-2_35⟩. ⟨hal-02282908⟩
348 View
259 Download
Share
