Observer Design for an Inverted Pendulum with Biased Position Sensors - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Izvestia Rossiiskoi Akademii Nauk.Teoriya i Systemy Upravleniya / Journal of Computer and Systems Sciences International Année : 2019
Inverted pendulums can be considered as an approximation for the stabilization problem for legged robots. In this paper we design a linear observer for a reaction wheel inverted pendulum under biased angle measurements. The reaction wheel is a flywheel that allows the free spinning motor to apply the control torque on the pendulum. In this paper we consider the stabilization problem in the presence of a constant unknown bias in the pendulum angle measurements; this problem has important practical implications, allowing for less precise sensor placement as well as a closer approximation for the control of legged robots. This paper provides a theoretical and experimental basis for the estimation of the velocities and the bias in the system.
Automatique
TeorSist1902002Aranovskii (2).pdf (271.46 Ko) Télécharger le fichier
hal-02282919 , version 1 (10-09-2019)
Stanislav Aranovskiy, Andrei Biryuk, Evgeny V. Nikulchev, Igor Ryadchikov, Dmitry Sokolov. Observer Design for an Inverted Pendulum with Biased Position Sensors. Izvestia Rossiiskoi Akademii Nauk.Teoriya i Systemy Upravleniya / Journal of Computer and Systems Sciences International, 2019, 58 (2), pp.297-304. ⟨10.1134/S1064230719020023⟩. ⟨hal-02282919⟩
152 Consultations
937 Téléchargements
