?? ?????? ????????????? ???????? ??????? ?? ?????? ?????????????????? ??????????? ?? ?????????? ? ?????????? ???????? // ???, pp.168-176 ,
?????? ?????????? ????????? ???????? ????????????? ??????? // Cloud of Science, vol.1, pp.163-195, 2018. ,
, , pp.14-24
??????????? ?? ?????????????? ?????????? ???????????? ????????? ? ????? ??????? // ???. ???. ????, pp.51-62, 2006. ,
Robust Balancing Control of Flexible Inverted-Pendulum Systems // Mechanism and Machine Theory, pp.539-551, 2018. ,
Simple Rotary Inverted Pendulum and the Control Device // Applied Mechanics & Materials, pp.445-448, 2016. ,
Linear Motor Driven Double Inverted Pendulum: A Novel Mechanical Design as a Testbed for Control Algorithms // Simulation Modelling Practice and Theory, pp.31-50, 2018. ,
A Java/MATLAB-based Environment for Remote Control System Laboratories: Illustrated with an Inverted Pendulum, pp.321-329 ,
An Analytical Formula for Optimal Tuning of the State Feedback Controller Gains for the Cart-Inverted Pendulum System // IFAC-PapersOnLine, pp.668-672, 2018. ,
Discrete Time Control Based in Neural Networks for Pendulums // Applied Soft Computing, pp.821-832, 2018. ,
A time-varying inertia pendulum: Analytical modelling and experimental identification // Mechanical Systems and Signal Processing, pp.120-138, 2014. ,
Approximate Output Regulation of Spherical Inverted Pendulum by Neural Network Control // Neurocomputing. 2012, pp.38-44 ,
, A Cube That Can Jump up and Balance // 2012 IEEE/RSJ Intern. Conf. on Intelligent Robots and Systems (IROS), pp.3722-3727, 2012.
